Shorland brake booster problems.
Not sure at all
That is why we going to use a pressure bleeder this week.
Having to buy one
Dual Cyl on front wheels is the issue
Anyone used a pressure bleeder?
Best Practices?1967 Land Rover 109
1966 Land Rover 109
Joshua TylerComment
Some folk plumb the fronts so the bottom cylinder is upstream of the top cylinders. In other words, the bottom wheel cylinder will be the first cylinder after the flex line, then the top cylinder, as opposed to the opposite way the factory plumbed the 2 wheel cylinders.
The theory is that the air will want to rise in the system so the bottom cylinder will get the fluid (and get bled) before the top cylinder, where the excess air from the bottom cylinder will gather.
The other way I've seen it done is by removing the backing plate, securing the wheel cylinders so they don't pop out, then bleeding with the brake backing plate sitting horizontally, so the cylinders are at the same height. Once the side is bled, reinstall the brake backing plate on the axle and do the other side. Kind of a huge PITA if you ask me...--Mark
1969 IIA - Tan
1969 IIA - BlueComment
Can anyone direct me to a store that sells the British brake line fittings or hoses? I may have found a shop to rebuild my remote brake booster, however I need to take it out , ship it, and want to drive it while booster is being repaired. I need a hose/ fitting to go from the old style brake master cylinder directly to the junction block, or a hose to connect both ends at the point where the booster was removed ( a simple brake fitting union? ). Thanks.
Thank you, it appears num 2 has a few unions, thanks!Our host would be my first call as they have just about anything. If not...........
http://www.pangolin4x4.com/Comment
I don't have the answer for you--In fact, I recognize almost nothing from your picture--but using this resource, you can probably get it figured out:
http://store.fedhillusa.com/technicalhelphowtopdfs.aspx
Oh wait--I just had another look. I recognize the front drive shaft and the steering gearbox arm.--Mark
Thank you, on a footnote, I have always had "problems" when bleeding the brakes. I found (as suggested many times), be sure all 4 brake shoes are adjusted correctly. Rover issued a bulletin years ago, jack the wheel, have a person hold brakes down solid, then adjust the snails as far as they go. Release brakes, ( drum will still be unable to move), then back off the snails carefully till wheel is free ( I allow for a very slight drag).They say it lines up shoes and puts least force on the snail adjusters. It solved my soft brake, ( long travel). THEN bleed the brakes as usuall.Comment
