Smoked Head Gasket
  • 64Blue
    • Sep 2007
    • 64
    Smoked Head Gasket
    Hi, I recently bought a 64 2a that had sat for 10 years, very similiar to a '69 I used to have. Relatively rough running when I picked it up, and a compression test showed 145, 90, 90, 145, so was pretty sure it was a blow head gasket at least. Sure enough! From the look of the head and the block deck, it looks like it's been happening for a while too...
    reinstalled everything, and didn'r run that great, so chasing through the fuel lines, filters, sediment bowl, carb, spark plug wires, plugs, rotor, cap, etc... good fun!
    Anyone else have this occur? Anything I should be watching for in addition to this that may have occurred as a result, or led up to this?
    Thanks!
ID:	173359Click image for larger version
  • siiirhd88
    • 389
    I have had two head gasket failures at the same location on two different trucks. Check the head and block surface to see if they are flat. Running for an extended time with the gasket blown can wear the surfaces.
    • Les Parker
      • May 2006
      • 2020
      Have you done a new compression test since the gasket was replaced? That would show some indicators.
      • 64Blue
        • Sep 2007
        • 64
        Definitely some wear on the block... but I think within tolerance (I need to check spec's on that).... honestly, I should just have the head machined to ensure it's not something I need to repeat... once I get it running OK, I will.
        • 64Blue
          • Sep 2007
          • 64
          Ok, so finally dragged the car to the house from the buddy's house, so I can work on it more... new compression test.... 140 across all 4... uncannily identical... adjusted the valves and checked them twice... Did get it running, but definitely rough. valve train sounds pretty loud (oil is up to good level)...it only runs when I have my foot on the accelerator.... definitely having a hard time with the timing... put a timing light on it and its very retarded....if I advance it, the engine dies... the choke has to be on to even get it going....
          any ideas or thoughts?
            A carb / mixture / fuel supply issue is what comes to mind if it only runs with your foot on the accelerator and you need choke to keep it alive in this warm weather.
            Out of curiosity, where are you in NH?
            • 64Blue
              • Sep 2007
              • 64
              OK.... I will check that out...
              Left Coast....Over South of Seattle in Tacoma...
                Ha! Nevermind--I don't know where I got the wild idea that we were located in the same state.
                • 64Blue
                  • Sep 2007
                  • 64
                  NH Brethren, and others... good news...
                  re adjusted the valves... clearly, someone (me) wasn't paying attention as intake on #2 was way out of spec... guessing 40 /1000ths... not sure what I was smoking....
                  reset the distributor
                  tore the Rochester carb apart, sprayed it out, buffed the piston, and put back together.... the big change there was the float spec.... is supposed to be at 1 9/16 and was at about 1 1/4 so definitely explains the flooding.
                  Reassembled and fired right up...
                  these rigs are amazing...
                  Now to go through all the fluids on the tranny, Diffs' Fairey, etc...
                  Any recommendations for gear oil?
                  Thanks
                  J
                  • 64Blue
                    • Sep 2007
                    • 64
                    Quick update.... Did a bit of research on the available GL 4 oils and ended up getting Amsoil 75w-90 for the gearbox and napa sta-lube 90w GL4 for the rest of the various over drives, differentials, transfer cases etc. Figured the amsoil would give me a bit of an easier time shifting. And go with Sta-Lube on the rest. Seems everything was a bit low so I am interested to see if its any quieter...
                      Are we taking any bets on the answer to this?
                      • slowmo
                        • Dec 2014
                        • 225
                        This solution is the best I have found for reducing the noise level in a Series rover:
Name:	ear plugs.jpg
                        --David
                        1959 TR3
                        1970 Series IIa 88" ("Homer")
                        My hovercraft is full of eels.
