Poor quality fuel pumps
  • slowmo
    • Dec 2014
    • 225
    #16
    Ha. I just remembered an inspiring fuel pump story. I bought the new mechanical fuel pump last summer hoping it would relieve the vapor lock problems I was having.
    After a day or so I had the same problem...truck dead. I noticed fuel was leaking at the pump which was a hint. Background info: I was coming back from lunch in my office type clothes. I couldn't see the source of the leak from the top so I took off my shirt and shimmied underneath. I could see it was leaking between the sediment bowl and the pump, so I tightened the bowl clamp...to no avail. Fiddle-dee-dee.
    I removed the pump (now I was adorned with black arms and face having had to work under the greasy beast). The rubber seal between the bowl and pump had swelled to about twice its' normal size (great selection of gasket material my little Pakistani friends) and of course it no longer offered any way of creating a seal. I dug around in a nearby trash can, found some cardboard, made a new gasket, reinstalled the pump and was back to work. (Fortunately no one called the police since a shirtless, grease covered, apparently homeless dude was combing through trash cans.)
    Back at the office I couldn't put my shirt on because I was covered in blackness. So in I trudged, shirtless with my shirt in my teeth, straight to the rest room in an attempt to cleanup (I had appointments so going home was not an option). Being the owner of the company I'm sure I provided the employees with another story of crazed behavior to discuss over the dinner table with their loved ones.
    So thank you Pakistani Guy. Thank you indeed.
    --David
    1959 TR3
    1970 Series IIa 88" ("Homer")
    My hovercraft is full of eels.
    • offshoretitan
      • Jan 2016
      • 23
      #17
      Originally posted by cedryck
      So this is still interesting to me as I drove this truck over the weekend, and in the same spot on my trip, engine dies. Starts immediatlely and runs fine till the next time. It seems like to avoid vapor lock the system needs a vent, but is not the tank vented enough at the cap? I think it is a combination of these awful mechanical pumps, and lock.
      I've had experience where the diaphram in the mechanical pump was weak and when run for a period of 20+ minutes it would lose its ability to actually stroke firmly enough to pump the required amount of fuel. After a period of rest / cool down it would again power the vehicle for 20+ minutes. It was very frustrating! A new mechanical pump cured the problem.
      • cedryck
        • Sep 2010
        • 836
        #18
        Thanks all for the feed back on the vapor lock issue's with mechanical pumps. Thought my 88 was possessed and I am glad, (not) to hear that others have suffered a headache with this annoying issue. SloMo that is an hysterical story you tell, thanks.
        The strange this is I never had this issue for a bout 6000 miles of driving, just started about 2 months ago.
        • leafsprung
          • 1008
          #19
          Use a genuine pump either NOS or rebuild a genuine pump. I put lots of miles on series rovers in all conditions and have gone through every iteration of electric and mechanical pump.
          • rejeep
            • Apr 2010
            • 420
            #20
            I have also found the quality of aftermarket pumps to be rather shoddy..
            I am suspect that my current aftermarket unit is leaking back into the engine contaminating my oil...
            snagged a NOS one to swap out this spring when the rover comes out of hibernation.
            1971 SIIa 88" NAS Dauntles V6
            1974 SIII 109" RHD
            • 64Blue
              • Sep 2007
              • 64
              #21
              Is there a good source for a rebuild kit from original manufacturer? I have an original pump installed that's leaks and a couple used spares in unknown condition... Would be great to get a few rebuild kits, but I can't seem to find them.... Any suggestions? Host and others don't seem to have them.....
              • 64Blue
                • Sep 2007
                • 64
                #22
                Moving this back up..... Anyone?
                • cedryck
                  • Sep 2010
                  • 836
                  #23
                  I would also like to know where a reliable, quality rebuild kit is ready for purchase.
                  • lumpydog
                    • May 2014
                    • 383
                    #24
                    Try googling Part #8G2039 or Part #AEU2760
                    Be warned that most genuine kits have the spring retainer cup, on the diaphragm, on the wrong side. The company that makes (made) them for Land Rover is located in Turkey and apparently couldn't be burdened with fixing this so people have just lived with it (they work fine with the retainer cup on the wrong side and the spring stays in place).
                    1968 Series IIa
                    • rickv100
                      • Aug 2010
                      • 143
                      #25
                      Then and now automotive carries rebuild kits as an AC style pump
                      73 xMOD S3 109
                      52 M37
                      • 64Blue
                        • Sep 2007
                        • 64
                        #26
                        rickv100 - can you please clarify.... more details please! what's automotive.....?
                        thanks!!
                          #27
                          thanks!!
                          Google "then and now automotive". You can't miss it.
                          • offshoretitan
                            • Jan 2016
                            • 23
                            #28
                            Here's their website:
                            • leafsprung
                              • 1008
                              #29
                              Kits
                              If rovers north does not have original kits I have both genuine land rover and AC kits and pumps new old stock
                              -Ike
                              • Les Parker
                                • May 2006
                                • 2020
                                #30
                                Be careful with some of those kits, the diaphragms have been known to be porous and not the best of qualities.
                                Les Parker
