Ha. I just remembered an inspiring fuel pump story. I bought the new mechanical fuel pump last summer hoping it would relieve the vapor lock problems I was having.
After a day or so I had the same problem...truck dead. I noticed fuel was leaking at the pump which was a hint. Background info: I was coming back from lunch in my office type clothes. I couldn't see the source of the leak from the top so I took off my shirt and shimmied underneath. I could see it was leaking between the sediment bowl and the pump, so I tightened the bowl clamp...to no avail. Fiddle-dee-dee.
I removed the pump (now I was adorned with black arms and face having had to work under the greasy beast). The rubber seal between the bowl and pump had swelled to about twice its' normal size (great selection of gasket material my little Pakistani friends) and of course it no longer offered any way of creating a seal. I dug around in a nearby trash can, found some cardboard, made a new gasket, reinstalled the pump and was back to work. (Fortunately no one called the police since a shirtless, grease covered, apparently homeless dude was combing through trash cans.)
Back at the office I couldn't put my shirt on because I was covered in blackness. So in I trudged, shirtless with my shirt in my teeth, straight to the rest room in an attempt to cleanup (I had appointments so going home was not an option). Being the owner of the company I'm sure I provided the employees with another story of crazed behavior to discuss over the dinner table with their loved ones.
So thank you Pakistani Guy. Thank you indeed.
