Hello again!
So after finally getting my '73 SIII running well yet another issue has arisen (I know, I know....this is probably to be expected).
For some reason in the last two weeks my Rover will no longer shift into 2nd gear. The issue isn't that it makes a grinding sound when I try to shift into 2nd but rather that the gear shift simply won't go into 2nd. The shift feels almost as if it is blocked from going into 2nd gear.
I have no problem getting it into reverse, 1st, 3rd and 4th but the gear shift won't physically go into 2nd gear. The first couple times it happened I pulled off to the side of the road, came to a stop, depressed the clutch and cycled the gear shift through each of the gears except 2nd a few times and then when I took off driving again I could get it to go into 2nd. I tried that tonight without success - the only way to get back home was to shift from 1st to 3rd gear.
I installed a new clutch master cylinder last spring. I haven't checked the slave cylinder yet but assume if that went then I would have problems getting into all gears?
Anybody have any thoughts on what might be going on or what I should do to troubleshoot this further?
Thank you as always!
