I'm working on a 1973 series III 88. The Rover has been sitting out in the elements for several years, and now the steering is VERY tight. I have isolated the problem to the Steering Relay column. Is this an easy part to disassemble and lubricate, or better off buying a new one? I'd like to try the former first so any advice would be appreciated. I see that 90 weight oil is recommended for lubrication, but where exactly does that oil go?
Steering relay column
Here's a steering relay rebuild guide I put together.
ColinComment
That's what I was thinking. Could be a steering damper, messed up swivel ball, etc. You might disconnect at the relay (if you haven't) for further isolation. No need to rebuild stuff now that doesn't need it (though you will likely have the opportunity to rebuild everything at some point).--David
1959 TR3
1970 Series IIa 88" ("Homer")
My hovercraft is full of eels.Comment
Sorry, should have been more clear. It's definitely the relay mounted in the frame in front of the radiator. I drained and refilled the steering column box and that is working just fine. The ball joints are also, for the most part, working fine though in need of new boots and some lube. It's the relay box that is jammed up. I was able to figure out how to refill with 90w oil, and it's been sitting overnight, but as of yesterday I could not get it to budge.Comment
This is definitely the part that is the problem, and my skill level, on a scale of 1-10 with 10 being professional, I'm about a 3! So I think I'll continue to try and tinker with it, but guessing I may end up buying a new one in the end.Comment
I started to reply to this thread and then thought - Colin nailed this one recently, wait for him to jump in :-)Here's a steering relay rebuild guide I put together.
Colin1968 Series IIa
1997 Defender SW (Original Owner - Sold)Comment
I wouldn't be scared to tackle rebuilding the relay. With that said, if you don't have the time or the desire to dig into it, replacements can be had for ~$100 + shipping. I've got other Rover parts I needed to spend the money on so I chose to spend about $8 to rebuild it. That left $100 for other Land Rover stuff - woohoo!!!
ColinComment
I struggle with this as well, is it worth the $, my limited time, or a combination of both. Time usually wins (especially since new parts are shipped to my dads where my wife can't find them on the door stepI wouldn't be scared to tackle rebuilding the relay. With that said, if you don't have the time or the desire to dig into it, replacements can be had for ~$100 + shipping. I've got other Rover parts I needed to spend the money on so I chose to spend about $8 to rebuild it. That left $100 for other Land Rover stuff - woohoo!!!
Colin
Mike
66 IIA
07 LR3
13 RR SportComment
Step one: Get the relay out of the frame cross member. When you achieve that, you will have a better ability to decide if you want to rebuild it, or if you have already screwed around long enough to just buy a replacement.Bad gas mileage gets you to some of the greatest places on earth.Comment
OK, so next question, perhaps not so easy to answer: how easily should that relay column spin around with some manual force? I re-attached the lower relay arm, tried to move it by hand and it wouldn't budge. I then fitted about a 3 foot long pipe over the arm for a bit of extra torque and I was able, with most of my strength, to get the thing moving. When it first starts moving there is a discernable "tink" sound of it loosening but then I'm able to move it back and forth with a good amount of effort. Should it be moving much more easily than this? I'm this close to just replacing it... Which brings on the next question - looks like the radiator needs to be removed in order for the relay column bracket bolts to be removed. Is that accurate?Comment
The relay has been known to be...um...stubborn... to remove. You can rebuild it without removing it from the chassis.Jason
It shouldn't be that tight. It probably has no oil in it causing it to be so stiff. Mine was difficult to turn when I removed it. Cracked it open and it was bone dry inside. The bushings need lubrication to ease the turning of the relay shaft. Once I rebuilt it, it was much much easier to turn. I could hold the relay in my hand and use a set of pliers to turn the shaft.
The radiator does need to be removed to get the bolts out. A bit of work just for two stupid bolts, I know.
ColinComment
I don't make enough money to buy new parts when I can overhaul the originals. I also don't make enough money to pay someone to do the work for me. This means things take longer than they should, but it also means my bank account is happy. I'm also a cheapskate when it comes to vehicles so even if I had the money I don't know I could bring myself to overpay for stuff and also pay the crazy, insane labor everyone wants to charge these days. "$150 per hour, we pay our techs $15 per hour, we think that's fair. Oh yeah, we also mark up all our parts to make money on those also."
ColinComment
