Those of you that saw my truck on Saturday might have seen the newly-developed pressure leak that I got on the way to the event. It seems to have gotten slightly worse. I used 2 quarts of oil just going to the event and back. It seems like the oil is coming out of the cap and blowing through the engine judging by where the oil is ending up (the air filter hose that leads to the carb, the bulkhead by the fuse box, the air cleaner itself on the top half, and the oil fill stem itself, as well as the top of the cap along the rim, not to mention a good portion of the underside of the truck and engine). Has anyone ever had this before, and if so, my question is..........could the engine suddenly start builing up a lot more pressure and blow the oil out of the vented cap?
A few of you saw the truck and noted that the tube at the bottom of the oil filler tube was bolted off, and the whole pcv valve setup was made inoperable by the previous owner, and it might be the cause. The only thing that makes me think otherwise is that the truck never lost a drop of oil (from the engine anyway) before this - so it's strange that it just came out of nowhere. Does anyone know what may have caused this - I know my solution is to put in the proper non-vented fill tube, but I'm still curious why this just started up when the engine was completely dry for 3 years prior to this. Thanks in advance...
