hey bosto-
pull the filter and replace it. while you are in there, make sure there is only one seal. sometimes there can be an old one stuck in the groove. dental pick to pull it out. also change the bottom seal while you are in there. I've also had sender units leak through the body of the unit so if the filter checks out then change that too. my old volvo 122 did that for a while before I figured out wtf was going on. lots of stuff in that area that can leak, clean it all up and watch while you run the engine in the driveway. you will find it...
Originally posted by Bostonian1976
