'64 Series 2A. Was driving home thought I heard/felt a very faint "snap" rolled up to a light to stop, truck came out of gear just fine. Went to shift into gear when the light went green and all I could do was grind gears without the tranny going into gear. Was able to turn off the motor, put the truck into 2nd, hit the starter button while it was in gear and get the truck running so I could limp home. Truck has been dripping hydraulic fluid from around the clutch slave cylinder and I've been adding fluid as needed. Replaced the resorvoir a couple of months ago because it was leaking. That went well and hasn't been an issue since it was done. Got a new slave cylinder and installed it, replaced the spring on the clutch linkage that wasn't there when I crawled under the truck, noticed this when I looked at the Haynes manual to get ready to do the slave cylinder. Just used a generic spring I had and it seems to have plenty of tension to return the linkage. I think the spring broke and may be what I heard/felt snap when the problem started. Have bled the system several times now and I still cannot shift the tranny into gear, it grinds as I try to shift. The tranny shifts between gears just fine with the truck not running with the clutch either in or out. Suspect that the flex line between the slave and the hard line to the master cylinder may be bad, I can't watch it and pump the clutch at the same time but the jacketing around the rubber hose is coming apart and it seems damp, maybe it's weeping fluid. I don't find a definite hole in it anywhere. Can't see where I'm missing something, or overlooking the problem. Any ideas or suggestions from the collective think tank?
Jeff
Jeff
