My gas engined Rover has just started to diesel when I shut it off. What is the cause and what is the cure?
Gas Engine Dieseling
umm... i don't know cause so for the most part i should be of absolutely no help at all......
...but here's my cure! :: stop vehicle > put in reverse > crank e - brake > turn off vehicle > dump clutch > and done!
happy friday all
~95 D-90 SW~
~72 Series III 88 RHD~ -
Check these things:
An engine continues to run when the ignition is shut off because it is still receiving spark and fuel.
Spark generally comes from carbon in the combustion chamber that continues to glow and provides a source of ignition. It can also occur from timing advanced too far.
Fuel is generally supplied from and idle setting too high.
With commercially available fuel, I have not seen engine run-on caused by too low of octane, but depending on region and age of fuel, things vary.
Good luck!
Jeff64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucksComment
Dieseling
Hello there,
Ref this issue, both Zenith and Weber offer a solenoid to shut the air/fuel down when the ignition is turned off. The "power end of the solenoid is connected to the coil, so when you turn the key off, the solenois automatically closes the air way.
So far, the success rate for both carbs. has been good.
Les Parker
Jim,
What kind of carb do you have?
We keep the Weber one in stock, I think I may have a used Zenith one available (tested of course).
Please advise,Les Parker
remove some carbon
you can take off the air filter, hold the throttle open and slowly pour some water down the carb, making sure you keep enough throttle to keep it running. Helps blow out the carbon that may be the problem.1968 battlefield ambulance/camper
1963 Unimog Radio box
1995 LWB RRComment
i would readjust the the idle, and retime your engine. clean readjust your points.never had to use this solenoid switch.Originally posted by JimCTyou can take off the air filter, hold the throttle open and slowly pour some water down the carb, making sure you keep enough throttle to keep it running. Helps blow out the carbon that may be the problem.Comment
Weber solenoid
Jim,
Part number is RNH390 and is priced at $41.21.
Please adviseLes Parker
Good to learn that the solenoid worked, we appreciate the feedback.
Keep on Roverin'
Les Parker
