My restoration project
  • ep7360
    • Oct 2007
    • 36
    Been working hot and heavy on the '69. Currently, I'm finishing up on the bulhead, brake and frame rework. I have also installed a Carter electric fuel pump which seems to work well. Here are some recent pictures.
Name:	69 brake detail.jpg
ID:	174708Click image for larger version
Name:	69 Brake.jpg
ID:	174709Click image for larger version
Name:	69 frame 2.jpg
ID:	174710Click image for larger version
Name:	69 transmission.jpg
ID:	174711Click image for larger version
Name:	69 frame.jpg
    Erik Peterson
    Gig Harbor, Washington
  • erik88lr
    • May 2016
    • 126
    Looking good! Mine was clean and shiny like yours, but that was 25 years ago!
    • Myron
      • 95
      Good going, Erik! The restoration is worth the effort. Mine's been mostly trouble-free since then, other than oil leaks of course.
      Come back and update your thread here. Would love to see your progress!
      Myron
      • vlad_d
        • Apr 2021
        • 246
        This looks great! Keep posting!
        One thing I noticed(maybe not a big deal):
        I'm in the middle of running brake lines, too. But my whole front sheet metal is all in place. I see you ran the brake lines up away from the frame. Will your wings/fenders clear the lines? I ran mine on top of the frame rails, or on the inside sides. Hold your fenders up there and see if you have access and clearance, or you might have to cut holes in the fender. FYI. (unless I'm missing something and you have a neat approach!)
        ...|______OD__|__\\_____
        1973 Series 3, 109
        • ep7360
          • Oct 2007
          • 36
          I haven't changed out the brake lines. I just removed the wings to help with the engine install. They are as they were previously and
          should fit.
          Erik Peterson
          • ep7360
            • Oct 2007
            • 36
            Engine rebuilt and Installed
            should fit.
            Here’s an update on my 1969 rebuild progress:
            Engine rebuilt (.030 over) with new valves. Installed and currently have about 300 miles so far on the break in. Runs better than it ever has! Installed a vintage vacuum gauge on the column and some new Yokohama tires. More pictures coming.
ID:	170362Click image for larger version
ID:	170363Click image for larger version
ID:	170364Click image for larger version
            Erik Peterson
            • jimrr
              • Dec 2010
              • 490
              looks great, I'm jealous as i'm waiting till i get my shop up to do much of anything to my rovers and they sure need help!
              • Kiloengineer
                • Dec 2011
                • 59
                Very nice work indeed! I'm about a year behind you.Click image for larger version
                1968 Series IIA
                1962 Jaguar Mk 2
