Starter Not Engaging '77 Santana 88 Series III
  • williamdmann
    • May 2022
    • 12
    Installed a new starter for my '77 Santana 88 Series III from Rovers North almost a year ago and it had been working quite well. Every now and then the Bendix would not engage and just spin but on a second try it would start up right off. Last night it started right up, however on my return home I went to start it and the bendix would not engage after numerous attempts. Ended up rolling it to start and get home. I removed the starter to see if the bendix was fouled in any way and it was completely clean.
    I have no idea what my next step should be.
  • jimrr
    • Dec 2010
    • 489
    does it sound like maybe the gear is hitting the flywheel but not engaging the teeth? Though I've never experienced any alignment issues with Landrover it could happen?
    • williamdmann
      • May 2022
      • 12
      Either that or the bendix isn't extending far enough yes. I just am not sure how I can determine which of those it is.
      • jimrr
        • Dec 2010
        • 489
        Whether or not it extends far enough you'll have to pull the starter and make some reasonably accurate measurements.
        as for whether or not it it can't engage the teeth I'd put some blueing or similar material on the flywheel where the proposed engaging happens and hit the starter a few times and then dismount the starter and have a look at the blueing and see if it shows signs of the gear hitting it.
        Thus: it measurements and a bench test tell you the gear throws far enough to engage yet there are marks on the flywheel where the gear hits but not engaging the teeth of the flywheel there is a alignment issue.
        I suppose some electrical wizard could tell you if it's possible the teeth could engage yet there isn't enough power to turn the engine for some reason. I'd watch the fan blade and see if it moves any fraction at all but the blueing should tell the tale for the most part.
        • roverp480
          • Jul 2020
          • 335
          It may be worth checking that all the starter leads from the battery and the earth lead from battery to frame and from frame to the engine & gearbox are all secure and in good order. I was convinced my starter was toast when it suddenly stopped working and it was just a corroded connection on the main lead. No prior warning at all.
          • williamdmann
            • May 2022
            • 12
            Yea the starter is receiving power, my main issue is I can't visually inspect whether the bendix is extending far enough to fully engage the fly wheel. One thought I had is removing the starter, connecting it to the battery and seeing if when powered if it's extending at all.
            • jimrr
              • Dec 2010
              • 489
              you can manually operate the bendix to measure it's throw distance by moving the gear tooth on the shaft.
              • williamdmann
                • May 2022
                • 12
                Yep I know it can extend all the way to the flywheel. It's worked without many issues for the past year. What I don't know now is was the throw distance not exactly right causing the faces of the teeth on the fly wheel to get ground away so now the previous throw isn't sufficient or is the bendix just not extending at all now.
                • williamdmann
                  • May 2022
                  • 12
ID:	170400Click image for larger version
ID:	170401Click image for larger version
ID:	170402Click image for larger version
                  Pulled the starter and the flywheel looks pretty mangled. Can the bendix throw be adjusted? The starter I bought was from RN and it's the high torque starter motor for Series II-III model # PLI029.
                  My follow up question is, did I get a defective starter or am I going to have to try and source a different brand. Or do I replace the ring gear and that should solve my problem.
                  • cedryck
                    • Sep 2010
                    • 836
                    [ATTACH=CONFIG]14284[/ATTACH][ATTACH=CONFIG]14285[/ATTACH][ATTACH=CONFIG]14286[/ATTACH][ATTACH=CONFIG]14287[/ATTACH]
                    The ring gear shows signs of wear, that is part of the problem, now so is the drive on the starter, the other part of the problem, you should replace or renew the flywheel teeth, and repair or renew the starter gear,
                    • jimrr
                      • Dec 2010
                      • 489
                      good info here as I bought one of those for my S2 because previous owners shop ran it out of oil. i got it to run but can't use it (another story) but now i'm wondering if the gear mesh is not correct? this seems the more logical fate of your fly wheel? I mean the gear count, maybe it's a bit off??
                      • roverp480
                        • Jul 2020
                        • 335
                        I also wonder if the gear teeth are not engaging properly, given the wear marks on both the flywheel and starter.
                        • charles1943
                          • Jan 2021
                          • 154
                          Suggest cleaning the bendix drive with 'brakleen' and then hit it up with some wd-40. See how it works on the bench and reinstall if function improves
                          • williamdmann
                            • May 2022
                            • 12
                            Yea I ended up throwing in the towel when I realized I couldn't swap out the ring gear myself. Taking it to a specialist here in town. My hope is that with a new ring gear they can get the alignment with the new starter correct and that will solve the problem. Since they have to pull the clutch while they're in there I ordered a new clutch plate as well so that can be replaced if it needs to.
                            • jimrr
                              • Dec 2010
                              • 489
                              well that should end the saga!, i need to pull my s2 engine for new inserts and who knows what else but it has to wait for the new shop. meanwhile i'm driving the s3 but it's getting pretty tired!. i'm still curious whether the gear count on that starter exactly matches the ring gear as i bought one of those starters as well?
