I am posting this here as I expect it will get more traffic than the 101 section.
I have a 101 in the US and need to overhaul the clutch master cylinder. Unfortunately some SPO has completely rounded off the fitting that seals the output pipe to the master cyl. With a healthy amount of swearing I will remove this but need to make up a new pipe for the reinstall. I assume that these pipes are just the standard brake pipe fittings and flare that are used on series trucks. Is this pipe flare and its fittings something I could buy a kit for in the US at some generic parts shop or do I need to obtain something from the UK? The inevitable question would be where can I get something to make up a replacement?
Cheers
Gregor
Cheers
Gregor
