Series 3 needs transmission help in Mystic Connecticut
  • timrod
    • Mar 2016
    • 1
    My 1971 Series 3 88" has developed a problem with second gear. Feels like the synchro is gone but I'm no expert. Looking to hire someone to help troubleshoot and repair the problem. Thanks in advance. Tim Floyd in Stonington.
  • westbound
    • May 2023
    • 17
    Tim,
    You can try Holland's Garage over in Guilford. That's the closest shop I can think of:
    Restore the optimal performance of your Land Rover or Range Rover by choosing Holland's Garage. Our auto shop serves Connecticut and the surrounding states.
    Mike is the owner.
    • yolikax
      • Oct 2025
      • 17
      Originally posted by timrod
      My 1971 Series 3 88" has developed a problem with second gear. Feels like the synchro is gone but I’m no expert. Looking to hire someone to help troubleshoot and repair the A-grade Used transmission problem. Thanks in advance. Tim Floyd in Stonington.
      Likely a worn second-gear synchro, which is very common on Series 3 88s. If it grinds going into second and improves with double-clutching, that’s the classic symptom. Other possibilities include worn dog teeth or a selector fork, but synchro wear is the usual culprit. Checking gearbox oil is worth doing, but a proper fix typically requires pulling and rebuilding the gearbox.
      • charles1943
        • Jan 2021
        • 157
        And if U need a rebuilt box I have 1 360-866-2254
