'67 Series 2a Clutch Wear - Possible Cause
  • GMorbey
    • May 2026
    • 4
    I have just acquired this "new for me" '67 2a 109. I knew the clutch was bad, so I picked it up using a U-Haul trailer and brought it back to North Vancouver. I decided to just pull the gear box back 20 centimeters inspect and remove the clutch. The previous owner had said the clutch was fine and the vehicle drove normally just a few days before, so why I wondered if the clutch was suffering from a rear main or gear box input shaft oil leak. What I found was a clogged drain, a very rusty (but dry) clutch cover, a completely worn out clutch disc (right down to the rivets), a very rusty flywheel, and a caked on mass of burnt clutch dust inside the bell housing - about 5mm thick. It did not appear wet near the bottom (assuming that's where oil would have gone), but it had coated everything in there pretty consistently. Brake Cleaner removed most of it with little effort. So I'm thinking that I do not have a rear main seal leak or a transmission input shaft leak. I also verified that the vehicle has the 9.5" clutch. I have a few questions at this point...
    1. Should I change the throw out bearing? It does not appear to make any noise.
    2. If yes, is this behind a small cover in the bell housing, and if this is removed, will it drain gear box hydraulic fluid?
    3. The clutch cover appears to have a steel triangular shaped central hub that mates with a similar size disc on the input shaft. This would be metal/metal contact in operation. Should this be lubricated when assembling?
    4. Unrelated, there are no reverse lights. Where is the reverse light switch located? I see no electrical connections on the gear box.
    Any input would be appreciated...
    Geoff.
    • 400
    tCongrats on the new to you 109!
    1- The throw out or release bearing on a 2A is quite robust and likely won't require replacement. Its bearing is lubricated by the trans gear oil and if the bearing is OK I wouldn't change it.
    2- If you remove the release bearing housing the transmission gear oil will leak out. Removing the housing reveals the input shaft bearing and front mainshaft bearing.
    3- The similar disc that mates with the triangle shaped surface on the clutch cover is the face of the throw out bearing. This should spin freely and rides on the triangle shaped disc when the clutch is depressed. The face should not be lubricated
    4- Reverse lights in the U.S. were required on imported cars beginning in 1968 and trucks a bit later. There was a switch actuated by the shift rods on top of the transmission near the bellhousing. You can add your own reverse lights actuated by a pull or toggle switch but local rules might require a dash light indicator to remind you the reverse lamps are lit.
    See the pics at the link showing the release bearing bits at: https://littlegreenlandy.com/2016/10...arbox-strip-1/
    It sounds like your clutch had been slipping for a while. This can be caused by several reasons including: clutch linkage free play out of adjustment, worn springs in the clutch cover, foot resting on the clutch pedal for an extended time, oil or water on the clutch disc, sticking release bearing mechanism, etc.
    The 2A has release bearing mechanism with a "U" shaped fork that pivots forward on a shaft to move the bearing surface onto the triangle shaped clutch cover boss. The shaft pivot surfaces can stick, and there is a pin that secures the shaft to the shaft and arm that connects to the slave cylinder. This pin can break either jamming the shaft or preventing it from moving the throw out bearing.
    Note that not all 2A clutch covers used the triangle shaped boss.
    • GMorbey
      • May 2026
      • 4
      That's great information... Thanks Bob. I do believe that the clutch was out of adjustment at every point (pedal, master and slave). There was no free play at any point. I'm in the process of removing all that and giving it a thorough clean, inspection and rebuild, then I'll follow the manual on putting it back together, which gives me a chance to install missing items and ensure everything is properly adjusted. I'm also going to reconfigure the cab with bucket seats and three point belts as my wife (a physio) doesn't want to drive in it without adequate protection for back/neck - so I'll have brand new bench seats to sell. As for back-up lights, I may just install some off roading lights with an illuminated toggle. The last thing I need to do is check over the disc brake conversion. While it was done a while ago, my understanding was that it never quite worked well with the servo assist. I found that the vacuum was installed to carburetor air intake rather than intake manifold, so I'm going to do a check on that whole system too. I also need to find out if they had used DOT5 or DOT3 brake fluid. I'm thinking the latter because of colour, but I used DOT5 in my classic MG, and its purple colour has changed and looks very much like DOT3.
      Geoff.
        • 519
        GM morbey, that is one of the very best diagnosis's i've read in quite a long time. siiir's reply was among the best i've ever seen here .......... (except mine of course) !!! his answer to back up lights is correct AND in keeping with Land Rover............ after all, a true operator remembers to take it out of 4wd when it's time, as well as using the back up lights only when you like to see them on............... a dark slow speed forest road or just when your are parked but want more light aroiund you. I can't add much here only I figure the previous owner had a heavy foot? I'm changing all the gear lube to synthetic, needs to be done every few years............... it's worth the cost. and you have bench seats??
        • GMorbey
          • May 2026
          • 4
          Thanks for that
          The vehicle has brand new bench seats, but I'm changing to seats that have a head rest or else my wife won't go in it. I was able to find some used Defender seats which are basically brand new. I'm going to see what it takes to get them in this weekend. Once that's done, then I'll figure out the seat belts. There will be a huge amount of electrical still to do... it's an absolute mess with miscellaneous wires, multiple fuse boxes, wires that end in oblivion seemingly going nowhere. Headlights are on with just side light switch, no side lights, short to ground on turn signals... and list goes on. I've repaired the side and turn signal wiring at the front and back, so now to the headlights, then I'll worry about everything else. Parts are starting to come in, so my weekends should be busy!
          Geoff.
            • 519
            Land Rover always used Dot 4 fluid .............. if you put dot 3 in there then 6 months or a year down the road all the rubber in your brake system turned to jelly ....... (ask me how I know)
            in your case though, with disc conversion they may of went to another fluid.......... I'm using Dot 5 now but on the next go around I might switch back to Dot 4. The whole question hinges on
            how much 'REAL" rubber is actually used anywhere anymore. ............ like wiper blades, they take a set, don't flex much, chatter across the window.......... too much plastic!
            till Vietnam the French had a monopoly on real rubber production except for africa and I understand that once again many of the big french rubber farms are run/owned by the french ............
            and there is some in africa ........ but it seems plastic is cheaper than rubber anymore so we don't often see the real thing.
