I have just acquired this "new for me" '67 2a 109. I knew the clutch was bad, so I picked it up using a U-Haul trailer and brought it back to North Vancouver. I decided to just pull the gear box back 20 centimeters inspect and remove the clutch. The previous owner had said the clutch was fine and the vehicle drove normally just a few days before, so why I wondered if the clutch was suffering from a rear main or gear box input shaft oil leak. What I found was a clogged drain, a very rusty (but dry) clutch cover, a completely worn out clutch disc (right down to the rivets), a very rusty flywheel, and a caked on mass of burnt clutch dust inside the bell housing - about 5mm thick. It did not appear wet near the bottom (assuming that's where oil would have gone), but it had coated everything in there pretty consistently. Brake Cleaner removed most of it with little effort. So I'm thinking that I do not have a rear main seal leak or a transmission input shaft leak. I also verified that the vehicle has the 9.5" clutch. I have a few questions at this point...
1. Should I change the throw out bearing? It does not appear to make any noise.
2. If yes, is this behind a small cover in the bell housing, and if this is removed, will it drain gear box hydraulic fluid?
3. The clutch cover appears to have a steel triangular shaped central hub that mates with a similar size disc on the input shaft. This would be metal/metal contact in operation. Should this be lubricated when assembling?
4. Unrelated, there are no reverse lights. Where is the reverse light switch located? I see no electrical connections on the gear box.
Any input would be appreciated...
Geoff.
Geoff.
