Is anyone using the Wolf wheels RN part number PLW216 on a series? They are 16x6.5 with a 2.75" offset. I have a set of 235/85/16s and need some wheels to put them on. Also, does anyone know if these are for tubes or tubeless? Thanks!
Wolf Wheel Question
You might want longer studs IIRC. That is the only issue I can think of. They look a little odd on a SWB to purists but 6.00 16s etc look odd on SWBs to most other people nowadays.Comment
I ran wolf wheels on my 88. The early II & IIa studs (1/2" OD I believe) are too short and the lug nut doesn't seat very wheel in the wheel. I upgraded the studs to the larger rover size (can't remember the diameter off the top of my head) and the studs were ~1/4" too short. The lugs nuts fit well in the wheel so it centered better than the older studs, though. I recall reading a thread on some rover BB that said the new, large diameter studs are too short on series rigs b/c wolf wheels are meant for Defenders & they use disc brakes. Land Rover shortened the stud length since no brake drum was used anymore. Not sure if this true...
R/,
LewComment
any suggestions on where to obtain longer studs to fit. Isn't there some law about the minimum distance the studs could protrude?Comment
There was a post on this a while ago- I think it should still be available if you search.
There is no law as far as I know that has to do with studs prodruding- the problem is they don't protrude they leave a portion of the inside of the nut exposed. This is because the wheel itself is thicker.Last edited by yorker; 01-04-2008, 02:39 PM.Comment
Does anyone know what a wolf wheel weighs vs. a stock wheel? I have never bent a stock wheel, so if they are that much thicker it seems to me that all you are doing is adding unsprung weight...61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
I'm about to upgrade the studs to my Dormobile to fit some wolf wheels. Here's a link I found a while ago:
I haven't ordered from them yet, but plan to do so soon. I'm not sure of the weight of my wheels (running 16 x 6.5 wheels), but I remember them being heavy without the tire.
R/,
LewComment
the wolf wheels weigh a lot, I bought 4 recently and they came in two boxes, marked with a warning label saying over 70 lbs, that means 35lbs or more per rim.Comment
