Originally posted by JimCT
kinetic energy recovery rope or winch?
duh! i know that now. i just thank god that that 2" ball went high. afterwards i looped a tow strap through the pto hole in the rear crossmember'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
'07 LR3 (Series Recovery Vehicle) -
ok, so to end this thread, towing and self-recovery - moving from "must have" to optional:- Shovel
- High-lift or other pulling device
- Tow strap 3" wide, 25,000 lb rated or greater, lenght ???
- 3/4" shackles - 3 or more
- KERR of suitable size 7/8" or greater
- winch (wire or synthetic line, with synthetic more desirable)
'68 109 3 door with multiple personalities
'03 Ford Excursion 7.3 diesel
'07 Porsche Carrera S CabrioletComment
chesOriginally posted by chester rides againok, so to end this thread, towing and self-recovery - moving from "must have" to optional:- Shovel
if your as daft as i you might want to add...a friend with turbine powered tracked vehicle'64 Series IIA 88 Canvas Tilt
'76 Spitfire 1500
Meh,
Turbine power is a dead end in the evolution of tracked combat vehicles. Diesels give just as much power, are far more economic in this role, are less sensitive to contaminents in the air they breathe and are much more predictable in their failure. (A tank without mobility is just a pillbox and turbines convert from go to scrap in an instant.)
Watch the next generation of US AFV's and they are all going diesel or hybrid using some form of diesel.
Anyway if you get stuck the friend you REALLY want has an M88 sitting in the yard.
Cheers
GregorComment
if it's mud, i suggest don't be lazy, use a shovel to minimize the forces on all points, on all vehicles. moving half a ton one shovel full at a time beats bent crossmember, busted cables and the surprize projectiles. after launching a 2" chromed ball at my buddy i got out and dug for a few minutes. i called it my penance for being stupidOriginally posted by thixonNo recovery point is fool proof. You can break you're frame using a KERR. Ask me how I know.'64 Series IIA 88 Canvas Tilt
'76 Spitfire 1500
Agreed on digging. We've all been there, some of us (like me) have to learn the hard way. In the afore mentionted case, my haste to get unstuck resulted in a bill for a new frame, and the time it took to do the frame swap. Sure was fun to do the swap though!Travis
'66 IIa 88Comment
thanks for everyones input. now i just have to find a good place to begin getting this stuff.
jeff'68 109 3 door with multiple personalities
Well mounted recovery points wont damage your frame. A winch should stall or a vehicle should fail to pull you out LONG before the point fails. I have never had a recovery point fail . . .ever. I cannot even imagine a recovery point failure that would require a frame to be replaced unless the frame was junk to begin with.
-recovery points are only as strong as what they are mounted to, rusty frame horns and rear crossmembers do not make good places to mount recovery points
-use closed rigging; open hooks and tow balls are a big nono
-use straps and shackles rated well in excess of any possible load you plan to place on them
-keep straps and sythetic lines in good condition.
Quality recovery gear and rigging is far cheaper than even one trip to the hospital . . .Comment
Ah yes, but pain is a great educator.Originally posted by leafsprungQuality recovery gear and rigging is far cheaper than even one trip to the hospital . . .
Just kidding but it seems to be the way some people learn. It always amazes me watching group recovery. Everything from using a winch with a wire rope that is rusted and kinked hooked to whatever happens to be convenient to the usual band of gawkers hanging around in the danger zone with a Bud Lite in hand etc.
The other thing I was taught was to always use a short strap to mount to the recovery points on the stuck vehicle. The pull can then be applied to this strap which will spread the load on the chassis thus greatly reducing the possiblity for damage.
Cheers
GregorComment
Jeff,Originally posted by chester rides againthanks for everyones input. now i just have to find a good place to begin getting this stuff.
jeff
Join a reputable club and ride along with them for a while- that will give you a great idea of what to buy and from where.
I'd suggest you join ours but it is in Central New York and that is perhaps too far for you to drive to go trail riding.Comment
Yorker,
Thanks for the PM's. I'm probably alot closer to Ottawa Valley Land Rovers as I sit 1 hr. south of Montreal.
I think Bob and I are going to form our own club...North Country Rovers
Jeff'68 109 3 door with multiple personalities
