Im guessing so, just curious
Salisbury front axle/diff for my 109
Originally posted by gallf1I thought about using either GBR or Rover Tracks shafts for my standard LR front axle but as it is currently 10 spline, I would have to change the thrid member to 24 spline. This means either a late Range Rover diff (which is two high at 3.54) or a Toyota third memeber swap PLUS THE AXLE SHAFTS!! Too much money.
You should be able to get good used 24 spline diffs for $50 or so, I bought complete 24 spline disco axles disc to disc for $100 ea.
Swap your 4.7 diffs over with a spacer.
OR buy a 24 spline ARB, Truetrac etc.
It can be a pretty inexpensive swap.Comment
here maybe these are of help.Actually I'll throw in the 109 v8& 1 ton ones I have too just for kicks.
Big Sandy on landrovernet.com posted them to your thread there but someone here might find them useful too.Last edited by yorker; 02-03-2008, 09:29 PM.Comment
That is one tough looking truck! Very nice workmanship. I think you have created a Land Rover that many of us would like to own.
What color of green did you go with? It is hard to tell from the pictures. It looks better than the typical Bronze Green.
-Richard
1967 NADA 109 IIa SW
1974 88 IIIComment
Front Axle
Thx for the feedback....for the paint I went with Land Rover Pastel Green....I forgot where I found the paint codes on the web, but I took the paint info to NAPA and they mixed up the paint according to the Dupont formulation and presto!
I then found a company that for around $150 will mix up a case of 12- 12oz spray cans of your paint...I use it for small parts and touch up.Comment
Front axle
Thx Matt...Sandy from LR Forums - UK was very helpful and I have what I need. The photo below is what I have on the way (plus both complete half-shafts).
I did see in another forum that the front tie rod (connecting both arms on the swivel balls) appears to have a slight factory bend in it to clear the front of the larger Salisbury differential cover when the tires are in full turn mode!
Big Sandy on landrovernet.com posted them to your thread there but someone here might find them useful too.Comment
Yeah I didn't realize I was talking to the same person on both forums- I guess I should actually pay attention to people's screen names!Comment
