where to find what my engine prefix means
  • msggunny
    • 621
    Ok, so my engine # is 95117557C, where do i find what the numbers mean? I found where the chassis number can id your series, but not one for the engine.
    Thanks!
    04 DII
    08 D3 (LR3)
  • msggunny
    • 621
    Wow,
    I didnt really expect this.
    I thought all the Series experts hung out here, guess i gotta ask it somewhere else......
    04 DII
    08 D3 (LR3)
    • O'Brien
      • Oct 2007
      • 134
      where is this number located, on your block? maybe with a little more info we can figure it out. patience!
      Matt
      '66 88 GM powered
      '89 SWB RRC (sold)
      '67 109 NADA 6cyl. Station Wagon #2 (sold)
      • Momo
        • 347
        Gunny here's your serial number decoded courtesy of CalVIN:
        951 Model: Land Rover, Series III
        Body type: Lightweight
        Wheel base: 88in
        Engine: petrol
        Model years: 1972-1980
        Destination: Home market, right-hand drive (RHD)
        17557 Serial number
        C Design: Two significant design modifications
        '60 SII Station Wagon
        '64 SIIA 109 Regular
        '68 SIIA 88 Station Wagon
        • msggunny
          • 621
          Thanks guys, but the number i gave is off the block not the chassis.
          Trying to find out if its a 5 MB or 3 MB with out having to tear the oil pan off.
          04 DII
          08 D3 (LR3)
          • Squire
            • 7
            The difference between a 5 and a 3 brg is the engine casing.
            If the engine block has smooth sides its a 3brg and if it has reinforcing Xs' on the side of the casing its a 5 brg.
            • Erin
              • 19
              There is a website, Glencoyne Engineering, http://www.glencoyne.co.uk/, that has some engine numbers listed. You will be able to determine the general specs of your engine there. The site also has some information for a 200 DI conversion for a Series truck rather than the TDI, pretty interesting.
              Erin
              • msggunny
                • 621
                Nice,
                Airportable is the same thing as light weight?
                if so then its defidently not the orginal engine:
                951xxxxxx Series III petrol 2286cc 3-bearing (fitted to 88 inch airportable)
                04 DII
                08 D3 (LR3)
