Replacing Bulbs: LEDs?
  • NC Rover
    • Dec 2007
    • 288
    Anyone replaced any light bulbs with LEDs? Any benefits? Heard of people doing this as they are suppose to last long, produce more light, use less energy...but i'm curious to see if anyone has done this with dash lighting, turn signals, etc?
    Shop our wide selection of LED replacement bulbs for cars, trucks, and SUVs! Browse headlights, tail lights, brake lights, turn signal lights, and more!
    1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
  • green 'n stinky
    • Nov 2007
    • 28
    I've thought about this too, but have not tried it. I think I've read that LEDs can cause a problem with older flasher units because they draw so little current, however.
    • Bostonian1976
      • 750
      it would probably just cause a very rapid flash, right?
      • green 'n stinky
        • Nov 2007
        • 28
        I would think that would normally be the case, but I believe I had read that it was possible that they could also just not blink at all. I wonder if adding a resistor to the circuit would solve the problem.
        There's also a company advertising complete LED replacement light assemblies for series/defenders in the UK Rover magazines but as I recall they are very expensive and look a bit too modern for a series (in my opinion). I prefer NC Rover's idea of just replacing the bulbs.
        • uralrover
          • Dec 2007
          • 46
          They Work Great
          When I rebuilt my series three I baught purpose built LED bulbs for my blinker lights and for the brake marker light. They Are Twice as bright as conventional lights, haven't failed even when the cover got broke off roading leaving them exposed to the harsh North-eastern salt roads and react faster then conventional bulbs. Testing them at .08Watts compared to the 4 watts the conventional bulbs ran has also helped make them work better with my standard flasher while towing the trailer which also uses them. I highly recomend getting a good set. But they are pricey, and as I've only had them in a year I cannot verify if there long term surviveability is justifying the price.....
          • Tim Smith
            • 1504
            I've been very very interested in LEDs just simply because I'm so geeky. Found a couple of replacements that look close but not being able to hold them in my hand, I can't be sure.
            Search "Britax Model no. L14" or "Rubbolite Model no. 838LED" and you should see some in there. They look like the defender round style lights. If you search "LED" you'll find a bunch and there are others that might be a good match as well.
            There is also these lights but they seem a little cheap...
            I'm more of a build it kind of guy and after seeing a few short instructables like this one: (http://www.instructables.com/id/How-...ortable-light/) I figure I'd rather try my hand at making some of my own to fit into the original housing. I'll probably never do it though.
            Those bulb replacements are interesting. Are they really that much brighter than the originals? How many LED's are in them? Any idea what brightness the LED's are in them? There are LED lights and there are LED LIGHTS!
            Discover the latest breaking news in the U.S. and around the world — politics, weather, entertainment, lifestyle, finance, sports and much more.
            As for the turn signals, you'll probably need to wire in an electronic flasher to handle the low power of LED's. You see a lot of boy racers with LED lights assemblies in their Honda's and it just looks cheesy when the flasher isn't timed right... if it works at all.
            I've just recently replaced my interior light with some under the counter "puck style" LED lights from home depot. I was sick of the old light shorting it's case against my interior.
            They were about $15 and work a treat. You simply cut off the transformer which makes 12 volts and then wire them directly to your truck. So far so good and they are modular so I can add more as I need. They even come with a handy on off switch so I can remember to not turn them off much easier now.
            Cheers,
            Tim
            • S11A
              • 218
              That's spelled Honduh.
              • NC Rover
                • Dec 2007
                • 288
                Good deal. Well I guess I'm going to go for it and order some LED products. I'll give everyone the rundown on the results once I get everthing installed.
                • groundhog
                  • Feb 2008
                  • 18
                  I've used the clear LED's in my rear military stop tail and rear fogs but I left the standard bulbs in the signals. The LED's are definitely brighter from the rear, but they lose the effect from the reflector in the lens assembly hence there is less light when viewed from a side angle. Overall a good swap.
                  • redmondrover
                    • Nov 2007
                    • 102
                    LEDs for interior lighting
                    First, a warning: I am not a LR purist. Non-standard, non-genuine parts/replacements/upgrades are fine by me. I am installing LEDs throughout the interior of our 109--dash area, footwells middle row floor and rear/cargo floor plus inside tuffy box. Just completed running power leads and have not actually hooked any up (its been too cold to solder outdoors). I am not looking for "daylight" lighting, just enough to see. When it gets dark at 4:30 or so in the winter and there is NO light inside, even a little illumination is helpful.
                    • NC Rover
                      • Dec 2007
                      • 288
                      Once you get it setup, could you possible post some pictures or the lighting if possible...or if you camera could take such pictures.
                      thanks!
                      • Tim Smith
                        • 1504
                        thanks!
                        2X!
                        • crankin
                          • Jul 2008
                          • 696
                          Has anyone done any of this yet?
                          Birmabright Brotherhood
                          Clint Rankin - 1972 SIII SWB
                          • xsbowes
                            • 258
                            When you swap the bulbs, I'd recommend you replace the relay with one designed for LEDs.
                            Our LED tail, brake, turn, and reverse lights are a long-lasting solution to keep your trailer safe and visible to other drivers. Free shipping on qualifying orders!
                            Also select an LED color that is the same as the lens cover.
                            Stacy
                            Motta S.A. Italy
                            • crankin
                              • Jul 2008
                              • 696
                              Hey Stacy,
                              Have you done this? If so...did you use the 3v. 5v. 12v, etc...?
