Anyone run 225/70/16s ?
225/70/16?
what's the common size? 235/85/16 ?'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in piecesComment
Only if she's 5'3.Originally posted by yankAnyone run 225/70/16s ?1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|Comment
it depends if it is an 88 or 109Originally posted by Bostonian1976what's the common size? 235/85/16 ?Comment
what's common for both?Originally posted by yorkerit depends if it is an 88 or 109
actually -- not to hijack - but since I will be getting lots of tires this year....
what would be a good size for my 15's on my limestone?
and the 16's on my blue station wagon? assume Goodyear or Bridgestone MT/R's
thanks guys'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in piecesComment
225/70/16, 28.4"x 8.9",
for free- sure- why not? the original 88's tire size was similar to that used by the Willys jeep for example:
109s used 7.50 16s which were 31-32" tall, 6.00 16s were 28" tall. So as long as you have a decent weight rating anything inbetween these would be ok.
I've seen a LOT of 88s on 235-75-15s.
Most people prefer the taller tires like 33 9.50 15's.Comment
