Hi folks, first time poster here. Thanks for taking a look.
I have a 1965 SIIA 88 with a relatively new 2.25 petrol engine, equipped with a Ducellier distributor. I recently replaced the camshaft, as the timing gear keyway sheared out of the old one. The timing is set correctly, and the distrubutor seems to be in good working order. Here's the problem: no spark to any of the plugs. Now before you start responding, read on. I have replaced and gapped the points, the condenser, the cap and rotor, the coil, and all of the plug wires and plugs. I have positive power to the coil, and I have positive power to the points when they are open and not when closed, so they are breaking the connection. However, I don't seem to be getting any power from the main coil lead into the cap, or from the cap to the wires, or from the wires to the plugs, and no spark from the plugs. I have checked and rechecked everything I can think of and I simply cannot figure this out. I would really really appreciate any help or advice or suggestions from any of you guys, because I'm at a complete loss here.
Thanks,
Ben
Thanks,
Ben
