Can you just test the "ground" wire that comes out of the distributor back to the coil and see if you have a circuit?
You may have a grounding problem inside the distributor itself, possibly grounding out at the points plate. By any chance, do you have access to an old Lucas distributor? Almost all of them in the Land Rover, Rover car, MG, Triumph, Sunbeam/Rootes lineups would work for this test. I'd sure be interested in dropping one in to see if you get a spark at the plugs. That would help you isolate the problem.
Jeff
While you're at it, do you have the two coil wires hooked up correctly?
Jeff
