Jim,
for my 73 SIII the wiring is as follows;
Starts with a White wire from the #7 fuse
into the wiring harness to the light on the panel
White/ Blue wire from there to the choke cable switch.
White yellow wire from there to the temperature sensoe at the front of the engine near the thermostat.
THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HT
There is a switch which mounts on the choke cable. There is an area on the cable just on the engine side of the bulkhead with a small hole (should be a metal sleeve on the cable here). The switch has a little post on it that goes in the hole (sounds kinky). When the choke cable in pulled out it activates the switch. When the engine warms up enough to activate the temperature sensor and the choke cable is pulled the light on the dash should come on. This tells you that the engine is warm and the choke is on.
