I went with old Ford blue...heres the p0rn
2 1/4 liter engine paint ?
It's a very modern Tata blue now.Originally posted by ML-ENGRI went with old Ford blue...heres the p0rnComment
That's pretty! It will soon have that unique mixture of oil, mud and more oil covering it.
Jason T.Jason
I just ordered a pint of that Austin Healey Green for my rebuild Great Color.. .. I can only hope it will look that good... Does anyone know if that block paint brushed or sprayed on?Comment
I don't know...Ill I know is that the 3 main bearings 2.25 are green and the 5 main bearings engine are paint red.Comment
'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
yes, same as mine BUT I have my #1 at the front of the motor, and the vacuum advance is at the front of the dizzy...so either the older motors were different or I screwed something up again.04 Disco, Gone-Disco died & so did mine
'72 S3 88 - Leakey & SqueakyComment
i dropped my dizzy drive gear in a bit off. about 1 spline counter clockwise from what the shop manual says so my dizzy sits a bit different than before my rebuild. maybe you did the same.'64 Series IIA 88 Canvas Tilt
'76 Spitfire 1500
Bmohan,
Don't sweat it. As long as the firing order is right, and you can still rotate the dist to the correct position for the truck to run properly (ie correct timing) you're fine.Travis
'66 IIa 88Comment
Go to a marine supplies place...they have the Detroit Diesel spray paint and it is the correct color for the engine. They should carry it by the truck-load!!"Were not here for a long time --Were here for a GOOD time!!"
'73 Series III
'06 HSEComment
