Originally posted by Rosie
Tires will impact fuel econmy if you don't maintain them at the Mfg. suggested inflation. Anything else is hearsay IMO
750R16 tires may make highway driving more bearable. Tires will not increase most speed related attributes like top end or acceleration times.
Depends how your steering is set up. If it is solid, then a similiar or slightly taller tire should not impact it. Significantly larger and wider tires will degrade it.
If your not going to do much off roading, go with the 600R16, 650R16 or even a 700R16 tire or equivolent. OEM tires in the day were small and very skinny.
29" to 30" or metric equivolents in an AT.
Here is what your truck most likely had originally. http://www.dunsfold.com/Sales/Specia...age%202007.pdf
That's 28.4 inch diameter and 6" wide!
Personally, I'd splurge and get a high quality Michelin XPS Traction in 215 or 235/85/R16. If your using it for business you could deduct some of the expense and it is retreadable and extremely durable. Never filed a farm or related return so I do not know what the IRS regs are.
EwS
