Show us your Series
  • achtung
    • Jan 2012
    • 40
    Originally posted by crankin
    Ah.
    Very Nice. Well done.
    • blue bomber
      • Dec 2011
      • 48
      Hello,
      New to this forum , but not rovers. Here are a couple of images of my ride.Click image for larger version
ID:	167091Click image for larger version
ID:	167092Click image for larger version
ID:	167093Click image for larger version
ID:	167094Click image for larger version
ID:	167095Click image for larger version
ID:	167096Click image for larger version
      Sent from my iPhone using Tapatalk
      • blue bomber
        • Dec 2011
        • 48
        A couple more Click image for larger version
ID:	167098Click image for larger version
ID:	167099Click image for larger version
ID:	167100Click image for larger version
ID:	167101Click image for larger version
ID:	167102Click image for larger version
        • eventhorizon
          • Jun 2012
          • 15
          SIII 109 1986 with Mitsu 4DR5 Turbo Diesel from a J55 Jeep
          Conversions done by PO in Thailand.
          • east high
            • Jan 2008
            • 337
            Digging those shots, blue bomber. I love those old black and yellow Cali plates. Which tires are you running?
            '67 sIIa 88
            • eventhorizon
              • Jun 2012
              • 15
              Blue bomber, are you running stock springs all around? The articulation looks as good as with paras. Definitely better than mine anyways, which are stock. I have to replace mine soon and trying to decide which route to take.
              • blue bomber
                • Dec 2011
                • 48
                Thanks for appreciating the little beastie. The fronts are stock springs with military shackles . I have added a caster shim to bring the caster back to 5 degrees. I'm going to run rear springs on the front sometime this winter, lengthen the frame etc. I am running 10" travel shocks and relocated the shock mount , both to clear the calipers and allow for more droop. The rears are genuine Santana parabolics with military shackles. Nothing too fancy.
                • blue bomber
                  • Dec 2011
                  • 48
                  Sorry guys I flipped quotes
                  The tires are33x12.50x15 on allied wheels with 3 1/8th " back spacing. I opened up the fenders to defender size.
                  • blue bomber
                    • Dec 2011
                    • 48
                    Very nice!!
                    • mrdoiron
                      • Dec 2009
                      • 446
                      Nice looking and capable rig!
                      Originally posted by blue bomber
                      A couple more [ATTACH]6623[/ATTACH][ATTACH]6624[/ATTACH][ATTACH]6625[/ATTACH][ATTACH]6626[/ATTACH][ATTACH]6627[/ATTACH][ATTACH]6629[/ATTACH]
                      1961 Ser IIa Hybrid Defender
                      1969 Ser IIa Bugeye
                      1998 Disco - ex wife :-(
                      2010 RR Sport Supercharged
                        Couldn't help but stop and take a pic with the sun shining and a thunderstorm passing 3 miles to the southeast. I just wish I had a better camera:
                        • eventhorizon
                          • Jun 2012
                          • 15
                          Thanks BB.
                          Did you extend the spring hangers as well to run the mil. shackles? Any negative effects to this mod?
                          • blue bomber
                            • Dec 2011
                            • 48
                            Looks great.
                            • mjones1700
                              • Jul 2012
                              • 40
                              What kind of crazy suspension do you have that allows you to do that? Looks like a Mars Rover maneuver. I like it.
                              • blue bomber
                                • Dec 2011
                                • 48
                                Thanks BB.
                                I did not extend the front hangers . The military shackles are a temporary measure. Without a lowering the front hanger and just using the shackles, you will have some problems. The front universal joint will get into bind and the caster is too much . I want to say 9 degrees. With a shim it works great. I have relocated my shocks and have 10 inches of travel. Works good for me. I am going to run longer springs on the front eventually. I 'm having too much fun driving right now. I don't want to decommission it for the swap!!
