Show us your Series
    • 519
    figures, my photo got lost, not sure what this is.......... i'm not going thru that again!
    • DarkForestCreature1
      • May 2025
      • 2
      Here's my two land rovers. 1967 109, currently missing the engine and a few other parts. In it's previous life it was owned by Ron Pederson, the owner of an Alpha/Rover shop in Nederland, CO, and this land rover was named Grokolina, and has "reunite gondwanaland" stickers on it. He had taken out the worn out 6 cylinder in prep for doing a V8 swap (and cut out the front crossmember too, not sure why). He never did the swap. I currently have an OM617/SM465/Dana18 setup to put in it, but also haven't gotten that done yet. Ended up moving to WA to help the folks out on the farm as they age, and haven't gotten the land rover transported up here yet. Being a Colorado truck, it has no rust. And no, the wings and grille aren't busted up, just they were all removed for the engine work, and they're only held on by like one or two bolts in that picture.
      Second one is a 1961 88. 2.25 gasoline/petrol. Bought by my dad in 1975, from the first owner, the sheriff of Moab Utah who had bought it new. It's all original, about 36k on it, and still runs, but needs a restoration. No brakes, not much electrical (starter motor and generator still work), and clutch sometimes doesn't work, and the tires are the ones my dad put on in 1975... little cracked now. But it'll start right up ever time, and drive around slowly (because of the no brakes and cracked tires). It was the car I learned to drive on (after learning how to do all the routine maintenance on it), and I want to restore it to full daily driver condition for short trips to town and such.
      • alaskantinbender
        • Dec 2012
        • 53
        More recent pictures of 2 of my lumps.
        73 S3 88 and a 63 S2A 109.
ID:	193446 Click image for larger version
        1963 Series 11A 109, Left hand drive, Koneg PTO winch, ACR 2.8L 5 bearing power plus Engine with weber carb. Truetrac gear driven limited-slip traction rear differential.
        • NH66_2A
          • Dec 2025
          • 1
          Just picked up last month for light restoration, maximum enjoyment! 1966 Series 2A 88”. Barn find, wasn’t listed anywhere. Got it, and nearly an entire other vehicle worth of parts for $2500. How’d I do? Doesn’t run yet. Need to put in new fuel pump and new ignition parts, and I think she’ll crank up.
          • DGRover
            • Nov 2025
            • 1
            After owning various other modern Land Rovers, I decided to finally purchase a dream truck, this is a 1979 Series III "Trayback". Rightly named Colonel Mustard, it required little work to get running and quickly became the daily driver over the summer. Multiple trips to the hardware store helped with the summer garden projects as well.
Name:	All hands on deck.jpg
            2005 Freelander, daily driver when its too wet or too cold for the SIII
            1979 SIII Trayback
            2003 Range Rover (Sold)
            1996 Discovery SE7 (Sold - still missing it)
