Show us your Series
  • Myron
    • 96
    Exactly! The name alone might make it worth a set.
    Funny you mention Firestone, as I saw a set today and came back and googled it. What a bizarre tread pattern. I couldn't quite decide if it was truly a better mousetrap or just a gimmick.
    Goodyear makes the Wrangler All Terrain "Adventure" in my preferred 215/85 size. It's a lighter duty tire, and of course the name is all wrong, but I might give those a whirl. Interestingly, I have a new Defender on order and that's the tire they build it with.
    Thanks again for your help!
    Myron
    • jp-
      • 981
      The tires I'm dying to get a hold of are actually Continental HSO Sand tires, but they aren't available stateside.
      The later Range Rovers and early Discovery's had a similar tire if memory serves. I believe it was a Michelin XS or XMS or something like that...
      Maybe it was the Camel Trophy Defenders that used the Michelin XCL I'm remembering.
      67 IIA 109" NADA Wagon (sold)
      • jacedo
        • Aug 2016
        • 6
        Oh Landy
        This is Oh Landy, formerly know in the Mendo circle as Chug. I've have him for about 7 years. Upgrades include new end-to-end electrical system, Forbyn 4-wheel-disc and dual-circuit SIII vacuum boost brake system, parabolic suspension, Exmoor interior w/ seatbelts, new steering rack, Forbyn heavy duty axles, freshly rebuilt Rochester carb, Mt Mansfield heater, Romerdrive, LED lights, Hitchgate rear tire carrier w/ custom center brake light, RN rockslides, new fuel tank, new wheels & KO2 tires. Next project is restoring a Tropical top with a Lasalle headliner.Click image for larger version
        • bttpe1961
          • Sep 2023
          • 7
          1971 Series 2a
          • swatsullivan
            • May 2024
            • 9
            I bought one almost exactly like that 1971 IIA, but the frame was too far gone.
            • swatsullivan
              • May 2024
              • 9
              Here is the 1960 Series II I am working on - will need a lot of work! Including a new chassis.
Name:	1960 Series II.JPG
              • ivanhoe
                • May 2024
                • 1
                Hello,
                I've been away from Rovers North since the 90s, great to be back! Picked up a 1965 Series IIa and time to put it back together. Looking forward to following the treads and getting on the trails.
                Regards,
                Jay
                1965 IIa 88
                1959 IIa 88
                1955 I 86 57134191 Sold
                1960 IIa 88 24437750 Sold
                • Lance Dahl
                  • Jun 2024
                  • 3
                  Good Day,
                  I am a new Series owner, we purchased "Clare" about a month ago and I am working to install a number of items the previous owner had purchased and not gotten to yet. "Clare" is a RHD 1983 109 Country Wagon, she was imported from England about eight years ago. The story is when imported she was the last of 16 registered 109 Country Wagons on the road. I have installed the RoamerDrive that was NIB along with the new finned Transfercase cover. I am trying to work through the middle-row seat belt installation, as he had purchased the two shoulder belts and the middle lap belt. I will be looking for some photo help confirming where the lower outside angled brace gets installed, the online photos I have found don't really show how close the brace when covering the folding seat lever. I also seem to have the original angled seat belt shoulder brackets behind the C-pillar. It has only one hole though so I am trying to figure out where to mount the retraction mechanism.
ID:	170561 Click image for larger version
ID:	170562Click image for larger version
ID:	170563Click image for larger version
                  • JamesF
                    • Aug 2024
                    • 3
ID:	192581 Click image for larger version
ID:	192582 1963 2A Swiss military vehicle. Recently put on the hardtop but I’m not sure I like the way it looks. I may try a bikini top.
                    • charles1943
                      • Jan 2021
                      • 158
                      Perfectly and professionally restored. Immaculate vehicle. One of the best out there. Everything works as it should. Absolutely no issues. Multiple Show winner. Drive anywhere. Very desirable colors.
                      LAND-ROVER, late SERIES IIa. This 1971 Land-Rover is the last year of the “all-metal-dash” machines before the Series III Land-Rover debuted later that same year. This Land-Rover was treated to a 6-year restoration by, and for Dare Britannia, Ltd., of Olympia, Washington. We showed it at our first professionally judged Concours d’Elegance (the Forest Grove Concours) where it brought me First in Class. Two years later at our nearest British Field Meet it took another First Place. On a field of exquisitely presented Aston Martins, Bentleys, Jaguars and other premiere British Marques this truck was awarded “Best Debuting Restoration of the Day”. It continues to command top honors wherever and whenever it is shown. In my 55 years of passionate dedication to Correct, Original Land-Rovers, this is our finest (short wheelbase).
                      This Land-Rover is classed as a short wheelbase DeLuxe Safari Station wagon, with the correct heat-shield roof and four jump seats in the rear cabin.
                      I plan no further restorations at this time because Dare Britannia is backed up for several years with ongoing client restoration work. The demand is unrelenting. My restorations have brought my Company more than 60 international awards, of which more than half are First Place or better…..far too many to begin enumerate.
                      I would describe this Land-Rover as not only immaculate but a superlative, brilliant-running machine in every conceivable way. Its road manners are impeccable. It drives and handles precisely like a showroom-fresh example. It performs spectacularly…..astoundingly well. No excuses. ALL parts are Genuine Land-Rover or their exact, precise equivalent. No excuses. The tires will be those of the buyer’s choosing….including new MICHELIN Military all-terrains or AVON Traction Mileages, both being in stock. And both superlative examples of the caliber of tire worthy of the Marque.
                      • troyfree
                        • 2
                        here is my 71 IIA Click image for larger version
Name:	Rover max flex.jpg
                          • 505
Name:	hauling bentonite into high ditch.jpg
ID:	192881i have a s2a thats in better shape but this one does all the real work.
                          • healeydave
                            • Feb 2023
                            • 5
                            Here's my new to me 1970. Came out of long term, original owner, dry storage in the Chicago area. Engine is seized, but frame and bulkhead are good. Interior is pretty good. Planning on making it a nice driver. Stay tuned ......
                            • charles1943
                              • Jan 2021
                              • 158
                              Here are my pics! Enjoy, Charles Kellogg / Dare Britannia
                                • 505
                                hauling bentonite into high ditch (apx 5,000 ft.) bought new, one owner (me) about a zillion miles!
