Bolt size HELP!!!
  • spechols
    • May 2007
    • 33
    Bolt size HELP!!!
    There are two threaded holes on the bottom of the differential case near the driveshaft. Does anyone know what size, thread, pitch they are?
  • Tim Smith
    • 1504
    I'm not understanding where you are talking. Is this a Sals or a Rover case?
    • spechols
      • May 2007
      • 33
      The bolt holes are the same on both. There are two small holes on the flat bottom of the case near the propshaft.
      I think they are a size 10mm with a 1.25 pitch.
      • sven
        • 174
        That sounds correct. I have the tap if you need it.
        99 D1
        73 Series III 88"
        95 RRC LWB
          It is on later Rover-type differential "third members". My '73 had this type of diff in the front with the Salisbury in the rear. The early Rover diffs didn't have the large rectangular block on the bottom. This block houses the oil passages to the pinion bearings and has 2 threaded holes toward the rear.
          Unfortunately, JUST THIS WEEKEND, I gave my old one away to another Rover enthusiast so I can't confirm the bolt size, sorry...
          • spechols
            • May 2007
            • 33
            Just need the bolts.
            I will find out today if I am correct.
            • Tim Smith
              • 1504
              I'm still lost but I'll take everyones word for it that there are said bolts on the third member.
              Old
              New
              • KevinNY
                • 484
                Mine does not have them either Tim, the coiler difffs have them.
                  The one with the bolt holes is a different style still...
                  • spechols
                    • May 2007
                    • 33
                    [quote=Tim Smith]I'm still lost but I'll take everyones word for it that there are said bolts on the third member. No bolts, just bolt holes on the underside.
                    • sven
                      • 174
                      Yes, Spechols has coiler chassis and axles.
                      99 D1
                      73 Series III 88"
                      95 RRC LWB
                      • Tim Smith
                        • 1504
                        Oh yes! I forgot about those. Thanks for reminding me.
                        • spechols
                          • May 2007
                          • 33
                          Well I found a 10m with 1.25 pitch threads and it does not fit.
                          It is too big in diameter.
                          It looks like 8m is too small.
                          Any ideas?
                          Anyone know the size?
                          • Leslie
                            • 613
                            Whitworth!
                            J/K!
                            I dunno......
                            Why are they there? For mounting a skid-plate for protecting the u-joint?
                            -L
                            '72 SIII SW 88"
                            '60 SII 88" RHD
                            • spechols
                              • May 2007
                              • 33
                              My guess is that they are there for assembly or something, but yes - I want to use them to mount a skid plate.
