Oh, interesting.
Got My Lightweight!! Stay Tuned for Project Updates and Plenty of Questions!
Originally posted by scottby flat i mean there's no center axle. all the swiveling hitches i've see have a center axle that extends towards the front that's about 2" in dia and 6-8" long such that you need a 2.5" hole through the cross mbr centered between the 4 boltsComment
I can't see your photos from work but if your hitch is like this one below it was used on vehicles with the military rear crossmember. The lightweights (at least mine has them) and 101s have holes for mounting in the front also.
you can get them here but they're pricey:
Stacy
Motta S.A. ItalyComment
scott here is one, shipping might be a bitch though:
for comparison's sake here is the US swivel type:
I think US trailers- at least the smaller ones have always had lunettes that swiveled so the smaller pintles didn't require that capability, larger lpintle hooks on US Army vehicles had that ability, some were spring loaded too I think.
Originally posted by yorker'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
Originally posted by scotteven this one would require cutt'n the cross memberComment
My seat box is now all set to go back on the vehicle, although who knows when that will be. Originally, I was going to just use the seat box ass'y as-is, but I decided to remove the seat rails, sandblast them, prime & paint them, then install with all new Grade 5 hardware.
I see you've taken over the house, niceComment
^^ The lower sides of the rear tub, right in front of the rear tires? If so, I'm not planning on removing them from the tub. They are riveted, bolted, spot welded and welded - so I'm not touching them.
By the way, a few nice Lightweight parts arrived today from TLR:
when you reinstall the inner fenders or mud/splash guards, use a nut or some washers to space the bottom of the shield out 1/4 of and inch from the bulk head, this allows anything trapped in there to escape and still protects the bulkhead. I just saw the picture on the first page or so of the bulkhead. the project looks great, keep up the good work.Comment
