My OD seems to work just fine, but it is fantastically loud when engaged at speed. I checked the little dipstick-on-a-bolt, and there seems to be oil well past the notch, but I pulled the inspection plate off and took a peek anyway:
Keeping in mind I know next to nothing about transmissions, let alone these overdrives, the first thing I noticed was that it smelled foul - very burnt. The gears themselves look OK to me, though you can see the faces have some pits and flakes out of them.
At the least I'll drain and refill it, but how much oil can I safely add back in? If it weren't for the dipstick I'd assume I could just top it right up to the fill hole, but is there some possibility of damage from overfilling? And what weight should I use - I know 90 would be the standard, could I put something like 75w140 in in hopes of quieting it down a little, or is that asking for trouble?
