Hella Replacement Headlamps
  • Jim-ME
    • 1379
    I'm interested in the Hella replacements. If I use the bulbs that are DOT legal do I need to upgrade the stock wiring? I've got an alternator and am currently running Silverstars.
    Thanks,
    Jim
  • jac04
    • 1884
    As long as you are running the H4 bulbs that are the same wattage as the standard sealed beams (55/60W if I remember correctly), then you will be OK with the stock wiring.
    With that said, it is never a bad idea to change to a relay set-up that powers the headlights directly from the battery.
    • TSR53
      • Mar 2006
      • 733
      You can just run the stock wattage H4 bulbs included with the Hella Vision Plus headlights, as you have the alternator. However, as jac04 said, the absolute best set up is get as much of the 12V+ (or more) to the H4 bulbs and headlamps as directly as possible. You will be surprised how much of a voltage drop occurs at the lights with stock wiring.
      I set up a four relay headlamp kit for a 1989 Audi 200 quattro avant I used to own with the European H4/H1 light set-up and ran a large wire directly from the battery to power the lights through the relays. This way all you do is use the switch in the dash to toggle over the relay. Using the relay method will enable you to run much higher wattage bulbs by keeping the full current and load away from the switch up in the dash.
      Make sure to take your time, solder, heat shrink well and keep it tidy. This of course won't be factory looking but will work really well. You ALWAYS need more light.
      MoF, I'm thinking of installing some of the Hella 4000 compact rallye motorsport series to my 2006 MINI Cooper S R53 in front. Yup, even with the factory HID xenons AND lower fog lights I still NEED more lights. Of course this all depends upon where you drive and the conditions, etc. I almost MINI'fied three deer the other day on my mountain tarmac stage drive home from Rovers North.
      Cheers, Thompson
      Rovers North, Inc.
      • yorker
        • 1635
        Your stock wiring as it left the factory was good enough for stock wattage bulbs, but you should consider the effects of the last couple decades on it. It is usually best to replace it with a relay kit like that sold by Susquehanna Motorsports.
        Land Rover UK Forums
        • Blueboy
          • 153
          Jim-ME,
          I have the DOT ok'd Hellas in the 109 and used the e-code H4 replacement headlamps in my Rangie - there is a huge difference in the light pattern you see in front on the road with the H4 being the better.
          If our hosts do not have the e-codes, Susquehanna Motorsports is another great vendor I've used in the past.
          Another choice if available is the old Cibie "Z" beam headlight.
          One of the original companies offering a replacement light back in the dark ages.
          Jaime
          One Life Live It
          • adkrover
            • Jan 2008
            • 206
            Another thumbs up for the Hella Vision Plus. They are a huge upgrade from standard sealed beam. I decided not to do the E-code as they are not DOT approved and are very happy with the Vision Plus. You'll have to decide on the condition of your switches and wires but the relay setup will eliminate any question if you have the time.
            • JSBriggs
              • 111
              ARB (and others) make a relay kit that routes power direct form the battery (with an inline fuse) to the lights so that you arent running all the power through the switch. that alone makes the stock 55/60 brighter. Once you have the relays, you can run then no-DOT super bright ones without fear of leting the smoke out of the stock wiring.
              -Jeff
              • TSR53
                • Mar 2006
                • 733
                I found a DIY wiring diagram that is very similar to how I built my European H4/H1 light set up. Basically, use a Bosch 30A relay for each low and high beam light. Only difference in this version is a clever fuse block (rather than my one fuse). Hopefully this will keep some of you guys busy over the holidays. Let the solder, rosin and heat shrink smoke away!
                Thanks go to the Australian Land Rovers Club down under for this!
                link here
                Cheers, Thompson
                Rovers North, Inc.
                • Blueboy
                  • 153
                  whenever I see diagrams like that I remember why chasing electrons (or a EE) convinced me to become a Civil instead.
                  colors look nice though!
                  Jaime
                  One Life Live It
                  • Jim-ME
                    • 1379
                    I don't understand why you would want to or need to keep one of the original headlight plugs. Can someone explain?
                    Thanks,
                    Jim
                    • greenmeanie
                      • 1358
                      Thanks,
                      Jim
                      You have to keep some of the original wiring so that the smoke has somewhere to escape from so that you know it's still a Rover?
                      • TSR53
                        • Mar 2006
                        • 733
                        Hi Jim,
                        Based on the above wiring diagram, you don't actually need to keep the original headlamp plug itself. The original headlamp plug wires are what toggle the relays on and off (your switch at the dashboard) and would make it easier to just keep the original plug there to stuff some spades into. Although, that may lead to some voltage loss using original connectors ? - these however don't carry the load... You could cut the plug off and attach the wires directly to the relay if you like, but then you would never be able to go back to original if you wanted.
                        Cheers, Thompson
                        Rovers North, Inc.
                        • TSR53
                          • Mar 2006
                          • 733
                          Of course what was I thinking!
                          Cheers, Thompson
                          Rovers North, Inc.
                          • Jim-ME
                            • 1379
                            So if I understand correctly, you can stick spade terminals into the original headlight plug to save having to run new wires to the switch and the dimmer switch?
                            Jim
                            • TSR53
                              • Mar 2006
                              • 733
                              Well, not really.
                              What you do is just keep your stock existing dash dimmer switch, plug ends and all the original wiring to and from the headlamp plugs as is. If you do need to make repairs to this wiring run, now would be the time. You won't need to modify it any, only keeping it a stock setup.
                              Assuming you are going to build up the four relay setup I posted, your original dashboard switches and wiring to the headlamps stay intact. Instead of plugging into the headlamps, you unplug them and then they just plug into the new wires to toggle on the relays.
                              This makes the relays take the full load of higher wattage bulbs instead of the dash switch.
                              Example would be *after* this is built and installed, when you toggle on your lights, the original stock dash switch sends 12v to the relay to then toggle on the lights, rather than turning the lights on directly.
                              Hopefully this helps you.
                              Cheers, Thompson
                              Rovers North, Inc.
