Hey guys just wondering on what you think the average price for a custom roll bar for a Light weight should cost? just trying to plan. I have seen a couple pictures but no prices. Just wanted to know what you guys thought for a simple roll bar that fits under the hoop set. thanks guys
roll bar price
There is no "average price for a custom roll bar for a Light weight" It depends on many factors: material, welding process, design, coating and so forth. There are not enough similar cages/bars in lightweights in the US to establish an average. Prices will very from a couple hundred for a generic bar to a couple thousand for something really nice. -
i went to a buddy's muffler shop who does cages for race cars and jeeps on the side... and it cost me around $200 for a cage that fits under the hoop set and is connected to the frame (vital). The cage is nothing special and this summer im going to be adding more to it, because its lacking diagonal supports, but i think i got what i paid for.
cage is on the left
heres a pic of the whole truck with just the cage (no hoop set yet)
-Robert------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
cage
1) Mandrel Bending is a process where a die is pulled through the tube while the tube is being bent. This keeps the tube from being pinched along the inner radius. Its a more expensive process. It is not necessarily stronger either. That cage was not bent using a mandrel bending process.Because I can see the mandrel bend impression in the top, right rear corner, I'm going to suggest you used a material with way too thin a wall section for my comfort.
2) You will be able to see the start and stop of the bend on the inner radius when any conventional bender is used. This is where the tubing is forced around the die. These marks are obvious on most materials even high quality ones
3) While the cage pictured is crude, the materials would cost more than 200 for HREW, it may be schedule 40 poop pipe.Comment
FWIW, I have been thinking about having a cage made for a couple years. Had 5 estimates from Pro Fabricators and Off Road shops. In CA you can't get a nice cage done for under $2000 and the semi trick cages will be upwards of $3kNor-Cal
67' 88"Comment
The cage from the pics in this post ran just over $3k. Nicest cage I have seen.
Nor-Cal
67' 88"Comment
that sounds about right!Originally posted by leafsprung1) it may be schedule 40 poop pipe.------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
What's that old saying?... Tubing for cages, pipe for poop...
Jason T.Jason
I think the tubes i ended up with are the standard generic muffler pipes, which IMO are too thin to support my rover or any rover. That is probably why this cage only cost $200 vs. the others in the $600 to $3000 range. This summer i'm going to make a new cage with thicker pipes and more support or find another shop to make it.------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
any one used the military roll bar? im looking to get something made that looks like that. just the bar with backing to support it.Comment
Originally posted by derekchaceany one used the military roll bar? im looking to get something made that looks like that. just the bar with backing to support it.
Thats coold looking! that would fit in with my desert recce light weight im doing. Got the britsih desert net to wrap around the roll bar. I just need to have enough room in the back for my M2 .50cal to swing a 180 degrees. I must say that is the collest roll bar set up i have seen thanks yorker!Comment
