roll bar price
  • Terrys
    • May 2007
    • 1382
    #16
    Originally posted by leafsprung
    1) Mandrel Bending is a process where a die is pulled through the tube while the tube is being bent. This keeps the tube from being pinched along the inner radius. Its a more expensive process. It is not necessarily stronger either. That cage was not bent using a mandrel bending process.
    2) You will be able to see the start and stop of the bend on the inner radius when any conventional bender is used. This is where the tubing is forced around the die. These marks are obvious on most materials even high quality ones.
    Forgive my improper use of the term 'mandrel', however, it's evident that the roll cage shown was done on a tubing bender used in an exhaust shop. None of the pipe bent in our fab shop at the foundry would have those ID impressions. Our piping assemblies, while not used for roll cages, was used for hydraulic (3500 psi), steam (450 psi) and in cooling systems in power plant and marine propulsion systems
    • yorker
      • 1635
      #17
      Originally posted by derekchace
      Thats coold looking! that would fit in with my desert recce light weight im doing. Got the britsih desert net to wrap around the roll bar. I just need to have enough room in the back for my M2 .50cal to swing a 180 degrees. I must say that is the collest roll bar set up i have seen thanks yorker!
      Derek that was part of the mine protection IIRC, I have a bunch more pics and links to the original sites posted on Guns and Rovers:
      Land Rover UK Forums
      • LaneRover
        • 1743
        #18
        Just remember that the big 1/2 circle roll bar is also a 'Roll it back over' bar - which is useful after the mine goes off. . . . . . not for you per se but more for the folks who come to get the Rover back.
        • Eric W S
          • 609
          #19
          Originally posted by Oscar
          One would think the only material strong enough and light enough to do the job is aluminum. Schedule 80 I would say. Too much weight aloft and you only increase the chance of rolling and "testing" your setup.
          There are plenty of steels appropriate for roll bars. The main purpose is not weight but strength. Look at every rock crawler out there - built with steel for safety not weight transfer.
          • Oscar
            • Dec 2008
            • 51
            #20
            Fact remains that putting a lot of weight up there raises the center of gravity. Aluminum is lighter for similar strength.
            Hannibal...... 1964 SIIA 88" NAS.....
              #21
              A higher COG will negatively affect any type of motor vehicle. There is a reason why nearly all professionally sanctioned types of motor sports use steel based tubing for cages. To get similar strength out of an aluminum tube you'd need a thicker wall, bringing the weight closer to that of steel. I can't say I've ever seen an aluminum cage that was designed as serious protection on a 4x4. I think a serious attempt of making one out of aluminum would cost more than the average series truck.
              Bottom line...no poop pipe, exhaust pipe, PVC, or folding chairs! They provide nothing more than a false sense of security.
              Jason T.
              • Eric W S
                • 609
                #22
                Weight is irrelevant in cage design. The object isn't to save your CoG but your life. Steel is the better choice for this application.
                I have never seen a properly designed cage for a trail truck impact CoG to any noticeable degree. You'd have to completely fail in the design of the cage.
