I'm almost done putting in my new wiring harness, and for the most part it's gone amazingly smoothly. I've hit two snags though: first is the brake switch.
The brake switch worked fine before I cut out the old harness, but no luck after. I appear to have a dual circuit setup from a santana, like this: http://www.heystee-automotive.com/pa...brks/servo.htm. The switch itself looks a little like a small spark plug or glow plug, with two spade connectors on one end and a button on the other, where it goes into the pedal housing to be actuated by a little plate. I tried putting a multimeter on it to check for continuity between the spades when the button is pushed, nothing. So either I'm completely misunderstanding how it works, or I broke it somehow disconnecting the old wires. Hints on either what I'm doing wrong, or where to find a new one?
Second snag is the wiper motor (very important here in Oregon). I had trouble with it when I first got the truck, and then it magically started working again. Now it's defying me again. I've got a decent ground to the ground spade, and a single wire bringing 12v from the switch to terminals 1 and 2. When I switch it on, nothing happens whatsoever. Am I right in assuming both those terminals are positive, or should I have one of them wired to another ground? If so, does it matter which?
Other than that, it's made a huge improvement. Truck actually sat for a full 5 days last week with the battery connected, without discharging at all. Amazing!
. It's a 67 NADA 109 like yours, but I don't know if the motor may have been replaced at some point with a different unit...
