Wife was out shopping last night so I thought Ii could steal some time wrenching on my truck. Went to replace the fuel pump when I came across this type of bolt securing it to the engine. I only have hex sockets, so what do I need to buy now??? Is this a typical bolt used or a P.O.S.T?
unusal bolt on fuel pump
I've never seen one like that on either of my II-A's, Bob. I have a couple of star sockets in my toolkit that might fit over that odd nut.
Anyone else ever seen one like Bob's photo?
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
http://www.landroverwriter.com -
I've seen tons of them--On F-18 fighter-jets. It's a spline nut. It should come out with a regular 12-point socket. Maybe even a 6-point, but it is designed for a spline wrench or socket. See:Originally posted by Jeff AronsonI've never seen one like that on either of my II-A's, Bob. I have a couple of star sockets in my toolkit that might fit over that odd nut.
Jeff
and http://www.fastenerdimensions.com/bolts_spline.html--Mark
That looks like a high strength 12 point shoulder nut or what he said above. I know they are used on the big end studs on the Rover V8 at least but it's been so long since I opened up my 2 1/4 that I can't remember what's used on it. My bet is that someone dipped his hand into the jar of fasteners and chose the fancy nut by chance.Comment
i've just completed a rebuild of my 2.25 and there ain't no nuts like that anywhere on it. the fuel pump is secure with 2 studs 5/16-24 about 1 1/4" long and 2 5/16-24 nuts that go on with 1/2" socket/wrench. the studs have 1/2" of thread on one end and 3/4" on the other. the shorter end goes into the plate that's bolted to the block'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
that was it! Jeff's mention of "star" socket got me thinking so when I went home for lunch I rummaged around some of my old tool chests (I frequent a lot of flea markets) and found a 12-point 1/2 socket that fit it exactly. Before this I never really knew why those sockets exsisted except to strip Hex-heads. Best believe those won't be re-used.
thanks guys04 Disco, Gone-Disco died & so did mine
'72 S3 88 - Leakey & SqueakyComment
I love those damn things! I'd put em all over if I had enough to go around.
I also like the 5 pointed (pentagonal) nuts. You ever see those?61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
12 points are about the only thing GM ever came out with that made sense. I thought 5 point was only waterworks, or one of those funky gascocks.Originally posted by jp-I love those damn things! I'd put em all over if I had enough to go around.
I also like the 5 pointed (pentagonal) nuts. You ever see those?Comment
