I'd research whether the 2.5 is a good bio candidate. The UK forums should have info on this. Finding and building one is another issue. Not that many stateside. I'd talk to Turner and get a rebuilt long block that has been gas flowed. A turbo version would be cool if you could locate one...
The 2.5 uses the same injectors as the 2.25, so I would expect it to do just fine with Bio-d or SVO.
Jim-ME - if you're buying a new stripped engine from Turner, why wouldn't you just get the 2.5 for the same price? Are the mounts different?
"Although they are not inexpensive I personally would go this route if I was willing to cut and weld my galvanized frame." per Jim-ME a few post ago...
Yes. And I thought the 2.5 and 2.25 were practically identical and the 2.5 would be a drop in replacement without any cutting or welding. Which is apparently not the case, which is why I asked the question in hopes of maybe learning something useful.
I always thought that the 2.5 was just a 2.25 with a different crank and a few other differences - but not motor mount differences. How different are they?
Motor mounts differently. You need to loose the battery from under the bonnet to in the cab.
on my recent trip from outside NYC to Rockville, MD an older VW Jetta TDI went by me.
next to the TDI logo there was a "runs on bio-diesel" sticker.
after reading that link it seems more trouble than its worth.
for LR content, my friend in Brasil had a '93 110 with a 200Tdi in it.
on our trip to Chile, his fuel pump died and he had to replace it at our camp site.
his reasoning for the failure was the diesel fuel was containing less and less sulpher for lubrication due to the addition of bio-diesel mixed with the regular diesel available at many stations.
Even International had in their manual for my 110 not to use bio-diesel in the 300Tdi which was too bad as the bio had a higher C value.
...his reasoning for the failure was the diesel fuel was containing less and less sulpher for lubrication due to the addition of bio-diesel mixed with the regular diesel available at many stations.
There was an extensive test of diesel fuel additives and their ability to counteract the damaging effects of the low-sulphur diesel fuel being sold today.
This test seems to go against your friend's belief about biodiesel. The biodiesel was blended with low-sulphur diesel and outperformed ALL of the other 18 diesel fuel additives. Read all about it at:
The following are the preliminary results of a research study on diesel fuel Lubricity Additives. There is likely to be further commentary and explanation added at a future time.
PURPOSE:
The purpose of this research was to determine the ability of multiple diesel fuel additives to...
