Rebuilding transfer case, I foolishly cut out old bushing in the end of the transfer case front output shaft and installed the new bushing without checking for proper fit on the main gear shaft. Unfortunately, the new bushing, which incidentaly is the same part number as the flywheel bush (rnc714) is too narrow diameter to accomodate the transfer case main shaft. I'm stumped - has this happened to anyone else and how did you solve it?
Thanks! C. B.
Thanks! C. B.
