Well,
I've started my bed repair. I'll try to continue posting to this thread as I progress. Thus far, I've removed the bed floor. I'll have to post pics of that tomorrow, as I left them on my work computer.
Tonight, I busted out the TIG, and welded patches into my corroded rear bottom section (where the tabs to the frame bolt on). I have'nt ground anything yet, and you'll notice that the tabs extend further than the bottom of the original piece. I wanted to make sure I had a little extra metal to pull over at the end of the weld. These photos stink, but you'll get the idea.
This project started off as an attempt to just rivet new metal into place, and go. As you can see, I ended up having to plug the holes on either side of the patchs where the rivets were. (I'll post pics of the rivet attempt tomorrow).
My plan is to flap disc everything smooth, and then weld beads on the back sides, that I won't grind smooth.
