oops
I just realized I made a little mistake in my instructions for static timing
In step 3) I meant to say you connect the other end of the test light to the points (at the low tension lead connection). Not to connect the test light to the low tension lead wire. Sorry for any confusion. You are looking to use the points as a switch to turn on and off the test light that way you can tell exactly when they open.
3) attach a test light to the low tension led at the points and the other end to the "+" side of the battery (I use the battery cause mines in the engine bay close to the dizzy and I'm assuming yours is)
. In step 3) I meant to say you connect the other end of the test light to the points (at the low tension lead connection). Not to connect the test light to the low tension lead wire. Sorry for any confusion. You are looking to use the points as a switch to turn on and off the test light that way you can tell exactly when they open.
