A few weeks ago my engine starting running rough and I have not been able to fix it so could use some help.
1963 Series IIA 109 Station Wagon
Turner 2.25 rebuild engine
Weber 34ICH carb
I first thought it was just an idle problem, so changed the inline fuel filter, removed and cleaned the idle jet and removed and cleaned the filter screen. No effect.
Actually, it runs rough at all speeds. It's not really noticeable just listening to the engine, but is obvious listening to the exhaust. There's also a noticeable lost of power when driving.
I have since done the following, all with no effect:
Removed and checked spark plugs: all nice and tan
Removed distributor cap, cleaned contacts, adjusted gap
Removed wires from coil, cleaned contacts
Opened top of carb, check bowl for sediment (nothing found), cleaned out bowl and blew carb cleaner through jets (though did not remove them...not sure how, do they just unscrew?)
Clamped off vacuum hoses to check for leaks
Sprayed carb cleaner around base of carb to try and detect vacuum leaks there
Tried clearing carb by putting hand over air intake and letting it suck until it almost stalls
None of this seemed to have any effect. I am not experienced on this kind of thing so it's possible I've just failed to notice something, but at this point I'm out of ideas. Any suggestions would be appreciated!
Weber 34ICH carb
