Well, I think I made some progress this afternoon.
I wasn't sure how to remove the carb jets but I decided to remove the top of the carb again and have another look. The main jet appeared to just screw out and sure enough it did just that. Looking through it the opening looked like a thin slit, which didn't seem right. A blast of carb cleaner through it and a much larger round hole appeared.
Starting the engine I was now getting white smoke out the exhaust, which I take to mean with the larger jet opening it was now running too rich. I turned in the adjustment screw and was able to make the white smoke stop.
But it's still running rough. I tried the hand over the air intake to try and finish clearing things. This seemed to help, but only briefly (the RPMs would go up and some times the puffing from the exhaust would actually stop for a second or two).
So I'm guessing I need to continue clearing things. Looking at the diagram, the fuel flows past the main jet into the emulsioning tube and air correction jet. It's not clear, does that just unscrew too? If so, that will be easy to clean.
There's also the pump jet. I don't see how that comes out though, any ideas?
Are there any other jets or whatever that might also need to be removed and cleaned?
