Anyone ever use exhaust wrap to cut down on the heat given off?
Exhaust wrap
Yep. worked well until the pipe disintegrated almost 2 years later. The wrap holds moisture to the pipe and makes the pipe itself run hotter. I wrapped a set of exhaust headers and they turned to rust dust in less than 2 years. I wrapped a section of exhaust pipe farther down and when I unwrapped it it was noticably a lot rustier than the pipe on either side.
Your mileage may vary.-
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
I had wraps on my 2.25 header for 5 years. They started to get a bit tattered and took them off. The header is just fine, but i do notice a lot more heat now that i dont have them on any more.
For the record, i didn't use the "wrap" i used this: http://www.thermotec.com/high-veloci...t-jackets.html
worked great, no issues with the header what so ever.
I will be getting some in the semi near future.First but gone: 91 3 door Disco "White Rhino"
04 DII
08 D3 (LR3)Comment
Is that material Refrasil?Comment
Not sure of the cost- and it would require removing and being without your headers for a bit..but I've heard good things about Jet Hot coating with regard to heat reduction. As a bonus you can have them coated in a finish similar to the intake- they'll look clean and won't rust.1960 Series II SWB
1994 NAS D90 ST
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic (sold)Comment
I have thought about that too, i just need to find a place locally that can do it. I wont be driving it much this winter so thats an idea...Not sure of the cost- and it would require removing and being without your headers for a bit..but I've heard good things about Jet Hot coating with regard to heat reduction. As a bonus you can have them coated in a finish similar to the intake- they'll look clean and won't rust.First but gone: 91 3 door Disco "White Rhino"
04 DII
08 D3 (LR3)Comment
Does the coating create other problems such as a loss of power?Not sure of the cost- and it would require removing and being without your headers for a bit..but I've heard good things about Jet Hot coating with regard to heat reduction. As a bonus you can have them coated in a finish similar to the intake- they'll look clean and won't rust.Comment
Nope. They actually claim performance improvements- but I doubt it would be noticeable in a Rover. We'd probably benefit most from reduced heat in the engine compartment and increased longevity of the header. Here's the link for more info:
1960 Series II SWB
1994 NAS D90 ST
I would disagree, in a Series Rover the performance in crease would be through increased longevity of the driver!!1958 107 SW - Sold to a better home
I wonder if putting this on the underside of the passenger compartment would be as effective as wrapping without the rust worries:
heat shield, exhaust wrap, sound dampening, heat wrap, insulation, rv insulation, heat barrier, insulating wrap, heat sleeve, exhaust insulation, sound barrier, heat protection, exhaust protection, sound protection, heat tape, rv restoration, turbo cover, header blanket, turbo insulation, wire insulation, wire protection, heat sleeving, high heat protection, basalt, lava rock
I painted my exhaust with high temp paint and was going to wrap it, however I'm not confident that would stop the rust for very long._________________________________________
1986 3.5l 110 SW Austrian FeurwehrComment
