Who's done a total 24v to 12v conversion?
  • Mudtub
    • 32
    #16
    I made a simple u bracket and mounted it on the right side of the motor where there are four holes foe the old gen. I went to napa and found a belt. It was very easy with no batt in the way.
    • kevkon
      • Aug 2009
      • 364
      #17
      I have a question regarding the alternator (Lucas 43 amp) wiring on a SIII. Why do some schematics show one brown wire from the alterator to solonoid while others show two? Was it a matter of using 2 lighter gauge wires?
      94 D-90 tdi
      72 Series III
      • jac04
        • 1884
        #18
        ^^ I was just looking at that myself, funny. My wiring diagram only shows one brown wire, but I have two.
        The two brown wires connect to different terminals on the alternator. The larger brown wire should be for the alternator output to the positive side of the solenoid. The small brown wire should be for the alternator "sense" terminal to the positive side of the solenoid. The brown & yellow wire goes to the ignition warning light.
        • kevkon
          • Aug 2009
          • 364
          #19
          I know, my SIII has only one from the alt to solonoid. Just wondering if that's correct or a PO changed it.
          94 D-90 tdi
          72 Series III
          • kevkon
            • Aug 2009
            • 364
            #20
            So should there be two or one ?
            94 D-90 tdi
            72 Series III
            • Les Parker
              • May 2006
              • 2020
              #21
              Factory wiring for the Lucas Alternator has 3 wires connected to the back of the alternator.
              Les Parker
              • Nium
                • Aug 2009
                • 400
                #22
                So one wire is for the Charge warning light, one is for the charging the battery, so what's the third (attached to S post on alternator, I think) for exciting alternator? If it is an exciting wire can't the charge wire just be jumped to the S post from the "+" post on the alternator and do away with the third wire?
                Walker
                1968 Series IIA-"Ronnie"
                88" SW, 2.25L Petrol, LHD
                • SeriesShorty
                  • Sep 2008
                  • 275
                  #23
                  Heck, and mine is even more different since it was a radio truck. I've got a whole bundle of wires going into my stock 90amp generator! It's making my head hurt thinking about it. I leave for vacation tomorrow in the Disco so poor Series is gonna have to wait his turn.
                  • jac04
                    • 1884
                    #24
                    You could do that, but the 'sense' wire is best connected directly to the positive side of the battery.
                    • kevkon
                      • Aug 2009
                      • 364
                      #25
                      I'm curious, why run two wires to the + batt ( solenoid)? Mine has one 10 ga. What gauge are the 2 wires?
                      94 D-90 tdi
                      72 Series III
                      • greenmeanie
                        • 1358
                        #26
                        The sense wire is best connected to the main load point of the harness and not the battery. Read the previously posted link for the detail.
                        I won't guarrantee this is the naswer but if your truck has been converted to a higher amp alternator then adding a second wire to the existing harness to make up current carrying capacity is a common trick rather than replacing them entirely with a single heavier gauge piece.
                        • jac04
                          • 1884
                          #27
                          Yup, sorry for the error. My sense wire is hooked up at the + connection at the solenoid.
                          • SeriesShorty
                            • Sep 2008
                            • 275
                            #28
                            Here are some pics of what I am working with since the FFR trucks seem to be quite a bit different.
                            A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                            Attached is the stock wiring diagram that shows all the wiring to the generator and generator/shunt panel. Scratching my head with what to do to hook up an alternator since I've got all these extra wires.
                            I'm back from vacation and figured I'd pick back up on this before it gets too cold to do much.
                            • scatterling
                              • 183
                              #29
                              I removed all of the wiring for the gen. and shunt panel. My alternator is the single wire kind - so all I had to run was a wire from the alt. to the solenoid.
                              Neil Hanekom
                              '73 LHD 88
                              '75 FFR 109 exMOD Build Photo's
                              '99 D1
