prepping and re-painting a hard top
  • kevkon
    • Aug 2009
    • 364
    #31
    Stupid paint question; Was the color of the top an option when the truck was ordered? For example was there only one top color available with a Marine Blue body?
    I had a LR dealer about a mile from my house when growing up and I seem to remember some differences.
    94 D-90 tdi
    72 Series III
    • NickDawson
      • Apr 2009
      • 707
      #32
      I would also like to know about colors - hoping to match that off-white almond color.
      • jrd51ox
        • Mar 2009
        • 112
        #33
        Off white color is called Limestone:
        DuPont
        Limestone 38505A
        PPG Deltron
        Limestone 46251
        Glasurit
        Limestone ROV105/S
        ........or Rustoleum Almond Spray Paint is very popular.
        • NickDawson
          • Apr 2009
          • 707
          #34
          Just to show you all what I'm dealing with, here are some pics.
          I'd hoped to prime it today, but it looks like rain.
          They are all here in more detail
          The top where it gets ugly, the gray is bare metal, the black a mix of bare metal and grime
          The back and sides are tooooo bad (by comparison)
          • Bertha
            • Nov 2007
            • 384
            #35
            Nick
            You need to do a really good job of cleaning that before attempting to paint it. I would buy a comercial type cleaner and scrub that top down really well before putting any sandpaper or paint on it.
            1971 88 (restored and as new)
            1967 88 (the next project)
            • NickDawson
              • Apr 2009
              • 707
              #36
              Originally posted by Bertha
              Nick
              Was thinking the same thing as I took the pictures...I'll see what I can find in the shops tomorrow.
              • stomper
                • Apr 2007
                • 889
                #37
                Prior to buying me Land Rover, It was my hobby to detail cars. (they are all under warranty, so I needed something to do).
                Buy a good all purpose cleaner (APC). Purple power, greased lightning, fantastic, 409. ect. the more industrial APCs are suppost to be diluted with water to be safe on most surfaces, but I would use it full strength. Wet the surface down with a power washer, or a strong water stream from the hose. spray on the APC, and let it dwell for 15 minutes, but do not let it dry to the surface. Mist with water from the hose if you need. Then use a brush or a scotch brite pad to aggitate the APC on the surface, and break up the dirt. Rinse well with water, and repeat as necessary.
                I would not even contemplate paint types, sanding, etc untill you get the surface clean. you need to be able to see what you are working with.
                • NickDawson
                  • Apr 2009
                  • 707
                  #38
                  Made some great progress with some TSP, a stiff brush and some steel wool
                  All the black grime is gone and I'm left with a lot a bare metal and very little paint.
                  Going to get some quotes on having it sprayed, but suspect I'll end up trying a rattle can job on my own.
                  • brucejohn
                    • Jul 2009
                    • 215
                    #39
                    My full top is okay, but my pickup top looks worst then yours. Following along here has me leaning toward the rattle can.
                    I wouldn't have thought about using TSP, that stuff is great for all kinds of uses.
                    1982 SIII 109 RHD petrol project.
                    • thixon
                      • 909
                      #40
                      Nick,
                      you need a D/A!
                      Travis
                      '66 IIa 88
                      • NickDawson
                        • Apr 2009
                        • 707
                        #41
                        D/A?
                        • Bertha
                          • Nov 2007
                          • 384
                          #42
                          Originally posted by NickDawson
                          D/A?
                          Dual Action(as in orbital sander) and 180 grit sandpaper-any coarser and you will see scratches through your paint.
                          • NickDawson
                            • Apr 2009
                            • 707
                            #43
                            Awesome idea! Got a plethora of sanders (I am not for want of power tools after remodeling my house) - I'll start with some 180 and go lighter from there.
                            • brucejohn
                              • Jul 2009
                              • 215
                              #44
                              Thanks for asking Nick, I was too embarrassed to. Last time I asked what some initials were the answer was some internet slang my 11 year old knew.
                              What a great suggestion. The tub on my SIIa looks like the PO took an angle grinder to it. Realized his mistake (or ran out of steam real fast) and stopped.
                              • thixon
                                • 909
                                #45
                                Nick,
                                I feel obligated to mention that you should wear a respirator or face mask at the least. Lungs full of old paint and aluminum dust is'nt cool.
                                Brucejohn,
                                next time ask. I propably should have exlained anyway.
                                Travis
                                '66 IIa 88
