Work lamp install
  • jrd51ox
    • Mar 2009
    • 112
    Work lamp install
    Just ordered a rear work lamp for my SIII from our host. First, does anyone have install tips or pics from past projects? *(hiding wires, switch locations, etc.)
    Also, I still haven't decided on a location. Suggestions or pics are welcomed.
    *Mine is an 88 hardtop.
    Thanks everyone.
  • scott
    • 1226
    if i had a hardtop i'd mount it above the rear door opposit the hinge side. that way you could point it into the tub when the door was openned to light up your tool box for those late night road repairs
    '64 Series IIA 88 Canvas Tilt
    '68 Series IIA RHD Ambulance
    '76 Spitfire 1500
    • Myron
      • 96
      I recently put mine on the right side of the car. I'd rather it was on the left, but then it would have fouled on the roof rack ladder. I ran the power lead to the dome light, and the ground straight down the corner of the roof (inside) to the tail lamp ground terminal. I've seen many other installations with the lamp in the center of the roof.
      Myron
      • Dav1550
        • 80
        Copied an install of ECR and made up a new bracket & spacer that fits under the rear door upper hinge. Saved from having to drill any holes and additionally position allowed for running the wire between the top and window side then down along the inside rear door frame over to the right interior light cover. From there the wires follow the wiring harness through the chassis to a relay mounted on the inside right wing and into the centre dash with a toggle switch & indicator light.
        • ArlowCT
          • Jul 2008
          • 238
          If you do any off-roading be careful on how high you mount it. I had mine mounted to the left side above the door, it was nicely protected with the roof rack at that point. First time I went into the woods without the rack I ended up ripping the light right off the truck with a branch that cleared the roof but then snagged the handle on the top of the light. Real quick way to bust a real nice expensive light.
          I now have two smaller lights mounted just below the body cappings to the lleft and right of the rear door. Wires run right into the compartments that hide the wiring for the rear lights. One nice thing about it not being up high is they don't shine right in your face as you walk up to the back of the truck.
          Cheers.
          • gudjeon
            • 613
            Mounted mine low just above a grab bar. Protected somewhat down there. The mounting stud is the same size as the back tub mounting bolts. Wired to a 20 amp rated lighted toggle on the dash. Cheap and cheerful.
            • kevkon
              • Aug 2009
              • 364
              I'm surprised no mentioned mounting it under the hood
              94 D-90 tdi
              72 Series III
              • jb_
                • Nov 2008
                • 47
                Or underneath so that you can admire the drips at night. LOL.
                Real men love drips.
                '74 Series III 109" RHD
                The Chaffcutter (choof choof phut phut)
                • NickDawson
                  • Apr 2009
                  • 707
                  The PO installed mine in the hard top (which leaves me ligh-less when I'm running the soft top)
                  The wires run along the inside 'gutter' and down the side of the windscreen. There is a switch on the back of the light itself. I have it wired to a fuse that is switched by the ignition.
                  • Nium
                    • Aug 2009
                    • 400
                    Nick,
                    Your spare is on the wrong end.
                    Walker
                    1968 Series IIA-"Ronnie"
                    88" SW, 2.25L Petrol, LHD
                      • 390
                      I mounted my work light on my soft top 109 on a bracket above (and behind) the license plate lamp. I bought the bracket from our host, but one could be easily made from aluminum or steel angle. The work light is actually a cheap halogen fog lamp, and is wired via a relay to an 'on-off-on' toggle switch and indicating light. In one position the work lamp and indicating light are lit, in the other position the work lamp comes on with the reverse lamps when shifted into reverse. The toggle switch is actually a Lucas turn signal switch from a Bugeye Sprite, and the indicating light is a blue high beam dash light from a '70s MG Midget.
                      '96 Disco SE7
                      '81 SIII 109
                      '75 SIII 88 V8
                      '68 SIIA 109 V8
                      • jb_
                        • Nov 2008
                        • 47
                        Originally posted by Nium
                        Nick,
                        My spare is in the middle. Is that a problem?
                        It is on the right. Maybe left hand corners are more difficult now?
                        I figured that the new retread tyre would be better inside. All the rest of the rubber bits on my Series are seriously degraded in a Land Rover kind of way.
                        I need to buy a kit of all the rubber bits.
                        • NickDawson
                          • Apr 2009
                          • 707
                          Nick,
                          HA!
                          Funny enough, the truck drives sooo much more nicely since moving it from the middle. I have the 3rd henge, so far, it seems to work well. Haven't take it off road with the counter weight yet.
                          • bmohan55
                            • Sep 2008
                            • 435
                            Originally posted by NickDawson
                            HA!
                            A 100lb+ tire on the hood is just the ticket for very steep hill climbs...as long as you don't mind guessing where the trail leads once you're up!
                            '72 S3 88 - Leakey & Squeaky
                            • jrd51ox
                              • Mar 2009
                              • 112
                              Thanks everyone...some great ideas, I'm sure I'll stress over this little project until Saturday, then just start drilling.
                              Still not 100% sure how I'm doing this yet, but will post a pic once complete.
