I don't think it's a matter of being fragile. It's an old truck and everything will eventually break. My frame is held together with nothing but hope and denial (waiting for RN to discount the 88 chassis or at least offer cheaper shipping) and along with that and my wobbly gear TC, I lashed a log chain to my storage building and drug is across my yard, spinning tires in 4lo. Friday I hauled a load and a half of firewood. I wouldn't abuse the truck, dumping the clutch etc, but I wouldn't have any reservations "using" the drivetrain.
I just finished playing with the SIII gearbox/TC I have on the shelf. It's very difficult to get the TC between gears, but I was able to do it and did produce a sound similar to that in the video. The lever detents that hold the the TC in gear are pretty robust. Although possible that the lever is being blocked from fully engaging, it seems pretty unlikely. The bottom of the red lever is bolted to the gearbox bellhoushing. A few inches up from that is a ball. This ball rides in a round bit that's bolted onto the end of the shaft that shifts the TC. There would have to be a lot of very tenacious debris wedged into the lever to prevent it from engaging Hi or Low.
I've been focusing on the TC, but it is possible that something in the gearbox has broken. If the layshaft or outputshaft broke, it might produce that same sound.
Good Luck and make sure you post pictures of the diagnosis.
