First, don't make it make those noises any more!
Second, remove the OD and I bet you'll find a stripped OD clutch sleeve.
The reason you see movement when the OD is in N is because it is free wheeling and the TC, immediately downstream, is no longer providing resistance (trying to make the truck move) and so the clutch sleeve doesn't slip. When it goes into gear, the clutch sleeve isn't strong enough to make the truck move so it slips. The clutch sleeve is a square-cut gear/bearing thing (pictured) that bolts onto the output shaft of the gearbox. It goes into and drives the OD. Sadly, if the easily-replaceable clutch sleeve is toast, the not-so-easily-replaceable driven gear in the OD is toast too.
That's my (revised) theory, anyway.
I love this board - post a video, get some input, go back out and start turning a wrench. Thanks guys for all the help and support.
